CH579M的FTP_Client例程无法进入下载步骤
程序“获取文件列表、文件名和时间”了之后,就提示“TCP Disconnect”,就无法进入“下载文件”的环节。我用“FileZilla Client”软件模拟,后发现需要再次“Connect”。有没有办法进入“下载文件”的环节时重新连接TCP。
这是FileZilla Client”软件的流程
这是CH579M的FTP_Client例程串口数据:
FTP Test
net version:16
mac addr:38 3b 26 26 8 28?
WCHNET_LibInit Success
SocketId TCP FTP = 00
PHY Link Success
TCP Connect Success
ftp sockid:0
check type= 01
len= 00000320
LOG:
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 4 of 50 allowed.
220-Local time is now 10:01. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
ftp sockid:0
check type= 01
len= 00000041
LOG:
331 User Firmware OK. Password required
ftp sockid:0
check type= 01
len= 00000032
LOG:
230 OK. Current directory is /
login success
login!
ftp sockid:0
check type= 02
len= 00000023
LOG:
200 TYPE is now ASCII
SocketId dat server:1
PORT :PORT 192,168,2,30,15,161
ftp sockid:0
check type= 02
len= 00000040
LOG:
250 OK. Current directory is /firmware
ftp sockid:0
check type= 02
len= 00000029
LOG:
200 PORT command successful
ftp sockid:0
check type= 02
len= 00000042
LOG:
257 "/firmware" is your current location
ftp sockid:0
check type= 02
len= 00000030
LOG:
150 Connecting to port 41143
ftp sockid:0
check type= 02
len= 00000042
LOG:
226-Options: -a -l?
226 4 matches total
TCP Connect Success
WCHNET_FTPGetSockeID:2
ftp sockid:2
check type= 02
len= 00000286
LOG:
drwxr-xr-x? ? 2 1000? ? ? ?www? ? ? ? ? ? ? 4096 Mar 31 14:50 .
drwxr-xr-x? ? 5 1000? ? ? ?www? ? ? ? ? ? ? 4096 Apr? 7 17:21 ..
-rw-r--r--? ? 1 1000? ? ? ?www? ? ? ? ? ? ? ?579 Mar 31 14:51 FTP_TYGV.txt
-rw-r--r--? ? 1 1000? ? ? ?www? ? ? ? ? ? ?20560 Mar 29 18:18 HC-07-B2001.bin
find file
ftp sockid:0
check type= 02
len= 00000050
LOG:
227 Entering Passive Mode (192,168,0,56,155,197)
WCHNET_FTPNoop
TCP Disconnect
search success
Error: 17
Error: 17
Error: 17
Send Data fail
显示“TCP Disconnect”,我尝试让TCP重连提示“Error: 17”
您好,我这边实际测试并未发现TCP Disconnect,正常使用中TCP是不会出现断开连接的,如果方便的话可以将代码发到wtf@wch.cn,或者拨打025-52638370详细咨询
我已经根据FTP指令表解决了,现在我想同时运行MQTT和FTP,但是它们两个的服务器端口不一致,我该如何解决?
您好,由于579M对于描述符的创建是看列表 SocketInf[WCHNET_MAX_SOCKET_NUM]中是否存在空闲,可以在创建完不同功能的连接后读取SocketID,用于区分是用于MQTT还是FTP。
