赤菟CH32V307VCT6外接TFT液晶屏
自己买的TFT液晶屏,商家只给了Arduino实例,请问要如何应用到赤菟上??
【SPI.h】
// Lcdwiki GUI library with init code from Rossum
// MIT license
#ifndef _LCDWIKI_SPI_H_
#define _LCDWIKI_SPI_H_
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#ifdef __AVR__
#include
#elif defined(ESP8266)
?#include
#else
#define pgm_read_byte(addr) (*(const unsigned char *)(addr))
#define pgm_read_word(addr) (*(const unsigned short *)(addr))
#endif
#include "LCDWIKI_GUI.h"
// LCD controller chip identifiers
#define ID_932X? ? 0
#define ID_7575? ? 1
#define ID_9341? ? 2
#define ID_HX8357D? ? 3
#define ID_4535? ? 4
#define ID_9486? ? 5
#define ID_7735? ? 6
#define ID_1283A? ?7
#define ID_1106? ? 8
#define ID_7735_128 9
#define ID_9488? ?10
#define ID_UNKNOWN 0xFF
//LCD controller chip mode identifiers
#define ILI9325 0
#define ILI9328 1
#define ILI9341 2
#define HX8357D 3
#define HX8347G 4
#define HX8347I 5
#define ILI9486 6
#define ST7735S 7
#define SSD1283A 8
#define SH1106 9
#define ST7735S128 10
#define ILI9488 11
#define ILI9488_18 12
#define ILI9486_18 13
typedef struct _lcd_info
uint16_t lcd_id;
int16_t lcd_wid;
int16_t lcd_heg;
}lcd_info;
class LCDWIKI_SPI:public LCDWIKI_GUI
public:
LCDWIKI_SPI(uint16_t model,int8_t cs, int8_t cd, int8_t miso, int8_t mosi, int8_t reset, int8_t clk, int8_t led);
LCDWIKI_SPI(uint16_t model,int8_t cs, int8_t cd, int8_t reset,int8_t led);
LCDWIKI_SPI(int16_t wid,int16_t heg,int8_t cs, int8_t cd, int8_t miso, int8_t mosi, int8_t reset, int8_t clk,int8_t led);
LCDWIKI_SPI(int16_t wid,int16_t heg,int8_t cs, int8_t cd, int8_t reset,int8_t led);
void Init_LCD(void);
void reset(void);
void start(uint16_t ID);
void Draw_Pixe(int16_t x, int16_t y, uint16_t color);
void Spi_Write(uint8_t data);
uint8_t Spi_Read(void);
void Write_Cmd(uint16_t cmd);
void Write_Data(uint16_t data);
void Write_Cmd_Data(uint16_t cmd, uint16_t data);
void init_table8(const void *table, int16_t size);
void init_table16(const void *table, int16_t size);
void Push_Command(uint8_t cmd, uint8_t *block, int8_t N);
uint16_t Color_To_565(uint8_t r, uint8_t g, uint8_t b);
uint16_t Read_ID(void);
void Fill_Rect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color);
void Set_Rotation(uint8_t r);?
uint8_t Get_Rotation(void) const;
void Invert_Display(boolean i);
void SH1106_Display(void);
void SH1106_Draw_Bitmap(uint8_t x,uint8_t y,uint8_t width, uint8_t height, uint8_t *BMP, uint8_t mode);
uint16_t Read_Reg(uint16_t reg, int8_t index);
int16_t Read_GRAM(int16_t x, int16_t y, uint16_t *block, int16_t w, int16_t h);
void Set_Addr_Window(int16_t x1, int16_t y1, int16_t x2, int16_t y2);
void Push_Any_Color(uint16_t * block, int16_t n, bool first, uint8_t flags);
void Push_Any_Color(uint8_t * block, int16_t n, bool first, uint8_t flags);
? ? void Vert_Scroll(int16_t top, int16_t scrollines, int16_t offset);
int16_t Get_Height(void) const;
? int16_t Get_Width(void) const;
void Set_LR(void);
void Led_control(boolean i);
protected:
uint8_t xoffset,yoffset;
? ? uint16_t WIDTH,HEIGHT,width, height, rotation,lcd_driver,lcd_model;
boolean hw_spi;
private:
uint16_t XC,YC,CC,RC,SC1,SC2,MD,VL,R24BIT,MODEL;
volatile uint8_t *spicsPort, *spicdPort, *spimisoPort , *spimosiPort, *spiclkPort;
? ? ? uint8_t? spicsPinSet, spicdPinSet? ,spimisoPinSet , spimosiPinSet , spiclkPinSet,
? ?spicsPinUnset, spicdPinUnset, spimisoPinUnset,? spimosiPinUnset,spiclkPinUnset;
? int8_t? ?_cs,_cd,_miso,_mosi,_clk,_reset,_led;
#endif
【GUI.h】
//#endif
#define LEFT 0
#define RIGHT 9999
#define CENTER 9998
class LCDWIKI_GUI
public:
LCDWIKI_GUI(void); // Constructor
? ? //These are defined by the subclass:
virtual uint16_t Color_To_565(uint8_t r, uint8_t g, uint8_t b)=0;
virtual void Draw_Pixe(int16_t x, int16_t y, uint16_t color)=0;
virtual void Fill_Rect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color)=0;
virtual void Set_Addr_Window(int16_t x1, int16_t y1, int16_t x2, int16_t y2)=0;
virtual void Push_Any_Color(uint16_t * block, int16_t n, bool first, uint8_t flags)=0;
virtual int16_t Read_GRAM(int16_t x, int16_t y, uint16_t *block, int16_t w, int16_t h)=0;
virtual int16_t Get_Height(void) const=0;
? virtual int16_t Get_Width(void) const=0;
//These exist only with LCDWIKI_GUI(no subclass overrides)
void Set_Draw_color(uint16_t color);
void Set_Draw_color(uint8_t r, uint8_t g, uint8_t b);
uint16_t Get_Draw_color(void) const;
void Draw_Pixel(int16_t x, int16_t y);
uint16_t Read_Pixel(int16_t x, int16_t y);
void Draw_Fast_VLine(int16_t x, int16_t y, int16_t h);
void Draw_Fast_HLine(int16_t x, int16_t y, int16_t w);
void Fill_Screen(uint16_t color);
void Fill_Screen(uint8_t r, uint8_t g, uint8_t b);
void Draw_Line(int16_t x1, int16_t y1, int16_t x2, int16_t y2);
void Draw_Rectangle(int16_t x1, int16_t y1, int16_t x2, int16_t y2);
void Fill_Rectangle(int16_t x1, int16_t y1, int16_t x2, int16_t y2);
void Draw_Round_Rectangle(int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint8_t radius);
void Fill_Round_Rectangle(int16_t x1, int16_t y1, int16_t x2,int16_t y2, int16_t radius);
void Draw_Circle(int16_t x, int16_t y, int16_t radius);
void Draw_Circle_Helper(int16_t x0, int16_t y0, int16_t radius, uint8_t cornername);
void Fill_Circle(int16_t x, int16_t y, int16_t radius);
void Fill_Circle_Helper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername,int16_t delta);
void Draw_Triangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1,int16_t x2, int16_t y2);
void Fill_Triangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1,int16_t x2, int16_t y2);
void Draw_Bit_Map(int16_t x, int16_t y, int16_t sx, int16_t sy, const uint16_t *data, int16_t scale);
void Set_Text_Cousur(int16_t x, int16_t y);
int16_t Get_Text_X_Cousur(void) const;
int16_t Get_Text_Y_Cousur(void) const;
void Set_Text_colour(uint16_t color);
void Set_Text_colour(uint8_t r, uint8_t g, uint8_t b);
uint16_t Get_Text_colour(void) const;
void Set_Text_Back_colour(uint16_t color);?
void Set_Text_Back_colour(uint8_t r, uint8_t g, uint8_t b);?
uint16_t Get_Text_Back_colour(void) const;
void Set_Text_Size(uint8_t s);
uint8_t Get_Text_Size(void) const;
void Set_Text_Mode(boolean mode);
boolean Get_Text_Mode(void) const;
size_t Print(uint8_t *st, int16_t x, int16_t y);
void Print_String(const uint8_t *st, int16_t x, int16_t y);
void Print_String(uint8_t *st, int16_t x, int16_t y);
void Print_String(String st, int16_t x, int16_t y);
void Print_Number_Int(long num, int16_t x, int16_t y, int16_t length, uint8_t filler, int16_t system);
void Print_Number_Float(double num, uint8_t dec, int16_t x, int16_t y, uint8_t divider, int16_t length, uint8_t filler);
? ? void Draw_Char(int16_t x, int16_t y, uint8_t c, uint16_t color,uint16_t bg, uint8_t size, boolean mode);
size_t write(uint8_t c);
int16_t Get_Display_Width(void) const;
int16_t Get_Display_Height(void) const;?
protected:
int16_t text_x, text_y;
uint16_t text_color, text_bgcolor,draw_color;
uint8_t text_size;
boolean text_mode; //if set,text_bgcolor is invalid
#endif
您好,附件为CH32V307 SPI驱屏例程,可以参考一下
icon_rar.gifCH32V307 硬件SPI LCD.zip
您好,没有,附件例程应该适用于大多数SPI驱动的TFTLCD屏,可参考一下
