macOS Sonoma 14.3.1 (23D60) 合宙 ESP32C3 经典版 CH343芯片无法识别 只会识别出 usbmodem
驱动安装的 macOS v1.8
CH340C识别成功:
Terminal 执行 ls -l /dev/cu*
结果如下
crw-rw-rw-  1 root  wheel  0x16000003 Mar 14 14:02 /dev/cu.Bluetooth-Incoming-Port
crw-rw-rw-  1 root  wheel  0x16000001 Mar 14 14:02 /dev/cu.serial1
crw-rw-rw-  1 root  wheel  0x16000009 Mar 14 14:20 /dev/cu.usbserial-14920
crw-rw-rw-  1 root  wheel  0x16000005 Mar 14 14:20 /dev/cu.wchusbserial14920
CH340G 识别成功:
结果如下
crw-rw-rw-  1 root  wheel  0x16000007 Mar 14 14:21 /dev/cu.usbserial-14910
crw-rw-rw-  1 root  wheel  0x16000005 Mar 14 14:21 /dev/cu.wchusbserial14910
CH343 识别不成功:
结果如下
crw-rw-rw-  1 root  wheel  0x16000005 Mar 14 14:22 /dev/cu.usbmodem56910213131
请问如何解决?
您好,麻烦提供下CH343 在你系统报告中,USB设备树中的信息我查询下驱动看看
悠灵你好,以下是我系统报告中的信息。
USB Single Serial:
  Product ID:0x55d3
  Vendor ID:0x1a86
  Version:4.45
  Serial Number:5691021313
  Speed:Up to 12 Mb/s
  Location ID:0x14920000 / 10
  Current Available (mA):500
  Current Required (mA):138
  Extra Operating Current (mA):0
| |   |   +-o USB Single Serial@02134000
  | |   |     |   "sessionID" = 291462593127
  | |   |     |   "USBSpeed" = 1
  | |   |     |   "idProduct" = 21971
  | |   |     |   "iManufacturer" = 0
  | |   |     |   "bDeviceClass" = 2
  | |   |     |   "IOPowerManagement" = {"PowerOverrideOn"=Yes,"DevicePowerState"=2,"CurrentPowerState"=2,"CapabilityFlags"=32768,"MaxPowerState"=2,"DriverPowerState"=0}
  | |   |     |   "bcdDevice" = 1093
  | |   |     |   "bMaxPacketSize0" = 8
  | |   |     |   "iProduct" = 2
  | |   |     |   "iSerialNumber" = 3
  | |   |     |   "bNumConfigurations" = 1
  | |   |     |   "UsbDeviceSignature" = <861ad3554504353734433033343737330200000202010a0000>
  | |   |     |   "USB Product Name" = "USB Single Serial"
  | |   |     |   "locationID" = 34816000
  | |   |     |   "bDeviceSubClass" = 0
  | |   |     |   "bcdUSB" = 272
  | |   |     |   "kUSBSerialNumberString" = "574C034773"
  | |   |     |   "USB Address" = 24
  | |   |     |   "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBHostFamily.kext/Contents/PlugIns/IOUSBLib.bundle"}
  | |   |     |   "kUSBCurrentConfiguration" = 1
  | |   |     |   "bDeviceProtocol" = 0
  | |   |     |   "USBPortType" = 0
  | |   |     |   "IOServiceDEXTEntitlements" = (("com.apple.developer.driverkit.transport.usb"))
  | |   |     |   "Device Speed" = 1
  | |   |     |   "idVendor" = 6790
  | |   |     |   "kUSBProductString" = "USB Single Serial"
  | |   |     |   "USB Serial Number" = "574C034773"
  | |   |     |   "IOGeneralInterest" = "IOCommand is not serializable"
  | |   |     |   "kUSBAddress" = 24
  | |   |     +-o AppleUSBHostCompositeDevice
  | |   |     |     "IOClass" = "AppleUSBHostCompositeDevice"
  | |   |     |     "CFBundleIdentifier" = "cn.wch.CH34xVCPDriver"
  | |   |     |     "IOProviderClass" = "IOUSBHostDevice"
  | |   |     |     "IOUserServerCDHash" = "b8c6c88f6bda93879aad895e2c535895e2bac098"
  | |   |     |     "kUSBPreferredConfiguration" = 1
  | |   |     |     "IOProbeScore" = 90000
  | |   |     |     "IOMatchCategory" = "IODefaultMatchCategory"
  | |   |     |     "IOPersonalityPublisher" = "cn.wch.CH34xVCPDriver"
  | |   |     |     "kOSBundleDextUniqueIdentifier" = <32cc96e0082529a5f940a90e4adec620cf01e26d4339a6db1d8853910ef30e2e>
  | |   |     |     "CFBundleIdentifierKernel" = "com.apple.kpi.iokit"
  | |   |     |     "IOPrimaryDriverTerminateOptions" = Yes
  | |   |     +-o IOUSBHostInterface@0
  | |   |     | |   "USBPortType" = 0
  | |   |     | |   "IOCFPlugInTypes" = {"2d9786c6-9ef3-11d4-ad51-000a27052861"="IOUSBHostFamily.kext/Contents/PlugIns/IOUSBLib.bundle"}
  | |   |     | |   "USB Serial Number" = "574C034773"
  | |   |     | |   "bcdDevice" = 1093
  | |   |     | |   "USBSpeed" = 1
  | |   |     | |   "idProduct" = 21971
  | |   |     | |   "IOServiceDEXTEntitlements" = (("com.apple.developer.driverkit.transport.usb"))
  | |   |     | |   "bInterfaceSubClass" = 2
  | |   |     | |   "bConfigurationValue" = 1
  | |   |     | |   "locationID" = 34816000
  | |   |     | |   "USB Product Name" = "USB Single Serial"
  | |   |     | |   "UsbExclusiveOwner" = "AppleUSBACMControl"
  | |   |     | |   "bInterfaceProtocol" = 1
  | |   |     | |   "iInterface" = 0
  | |   |     | |   "bAlternateSetting" = 0
  | |   |     | |   "idVendor" = 6790
  | |   |     | |   "bInterfaceNumber" = 0
  | |   |     | |   "bInterfaceClass" = 2
  | |   |     | |   "bNumEndpoints" = 1
  | |   |     | +-o AppleUSBACMControl
  | |   |     |       "IOClass" = "AppleUSBACMControl"
  | |   |     |       "CFBundleIdentifier" = "com.apple.driver.usb.cdc.acm"
  | |   |     |       "IOProviderClass" = "IOUSBHostInterface"
  | |   |     |       "IOProbeScore" = 60000
  | |   |     |       "IOMatchedAtBoot" = Yes
  | |   |     |       "InterruptPipeReturn" = 0
  | |   |     |       "IOPersonalityPublisher" = "com.apple.driver.usb.cdc.acm"
  | |   |     |       "CFBundleIdentifierKernel" = "com.apple.driver.usb.cdc.acm"
  | |   |     +-o IOUSBHostInterface@1
  | |   |     | |   "bInterfaceProtocol" = 0
  | |   |     | |   "Product Name" = "USB Single Serial"
  | |   |     | |   "bInterfaceClass" = 10
  | |   |     | |   "bInterfaceSubClass" = 0
  | |   |     | |   "bInterfaceNumber" = 1
  | |   |     | |   "IODEXTMatchCount" = 2
  | |   |     | |   "bNumEndpoints" = 2
  | |   |     | +-o CH34xVCPDriver
  | |   |     | | |   "IOClass" = "IOUserSerial"
  | |   |     | | |   "kOSBundleDextUniqueIdentifier" = <32cc96e0082529a5f940a90e4adec620cf01e26d4339a6db1d8853910ef30e2e>
  | |   |     | | |   "IOUserClass" = "CH34xVCPDriver"
  | |   |     | | |   "IOUserServerName" = "cn.wch.CH34xVCPDriver"
  | |   |     | | |   "idProduct" = 21971
  | |   |     | | |   "IOPersonalityPublisher" = "cn.wch.CH34xVCPDriver"
  | |   |     | | |   "IOResourceMatch" = "IOKit"
  | |   |     | | |   "IOPowerManagement" = {"CapabilityFlags"=2,"MaxPowerState"=2,"CurrentPowerState"=2}
  | |   |     | | |   "IOProviderClass" = "IOUSBHostInterface"
  | |   |     | | |   "HiddenPort" = Yes
  | |   |     | | |   "IOProbeScore" = 89999
  | |   |     | | |   "IOUserServerCDHash" = "b8c6c88f6bda93879aad895e2c535895e2bac098"
  | |   |     | | |   "IOMatchedPersonality" = {"IOClass"="IOUserSerial","CFBundleIdentifier"="cn.wch.CH34xVCPDriver","IOProviderClass"="IOUSBHostInterface","IOUserServerCDHash"="b8c$
  | |   |     | | |   "IOTTYBaseName" = "wchusbserial"
  | |   |     | | |   "IOUserClasses" = ("CH34xVCPDriver","IOUserUSBSerial","IOUserSerial","IOService","OSObject")
  | |   |     | | |   "CFBundleIdentifierKernel" = "com.apple.driver.driverkit.serial"
  | |   |     | | |   "bConfigurationValue" = 1
  | |   |     | | |   "bInterfaceNumber" = 1
  | |   |     | | |   "IOMatchCategory" = "cn.wch.CH34xVCPDriver"
  | |   |     | | |   "CFBundleIdentifier" = "cn.wch.CH34xVCPDriver"
  | |   |     | | |   "idVendor" = 6790
  | |   |     | | |   "IOServiceDEXTEntitlements" = "com.apple.developer.driverkit.family.serial"
  | |   |     | | |   "IOTTYSuffix" = "574C0347731"
  | |   |     | | +-o IOSerialBSDClient
  | |   |     | |       "IOClass" = "IOSerialBSDClient"
  | |   |     | |       "CFBundleIdentifier" = "com.apple.iokit.IOSerialFamily"
  | |   |     | |       "IOProviderClass" = "IOSerialStreamSync"
  | |   |     | |       "IOSerialBSDClientType" = "IOSerialStream"
  | |   |     | |       "IOProbeScore" = 1000
  | |   |     | |       "IOResourceMatch" = "IOBSD"
  | |   |     | |       "IOMatchedAtBoot" = Yes
  | |   |     | |       "IOMatchCategory" = "IODefaultMatchCategory"
  | |   |     | |       "IOTTYDevice" = "wchusbserial574C0347731"
  | |   |     | |       "IOCalloutDevice" = "/dev/cu.wchusbserial574C0347731"
  | |   |     | |       "IODialinDevice" = "/dev/tty.wchusbserial574C0347731"
  | |   |     | |       "IOPersonalityPublisher" = "com.apple.iokit.IOSerialFamily"
  | |   |     | |       "CFBundleIdentifierKernel" = "com.apple.iokit.IOSerialFamily"
  | |   |     | +-o AppleUSBACMData
  | |   |     |   |   "IOClass" = "AppleUSBACMData"
  | |   |     |   |   "CFBundleIdentifier" = "com.apple.driver.usb.cdc.acm"
  | |   |     |   |   "IOTTYBaseName" = "usbmodem"
  | |   |     |   |   "IOProbeScore" = 49998
  | |   |     |   |   "IOMatchDefer" = Yes
  | |   |     |   |   "IOPersonalityPublisher" = "com.apple.driver.usb.cdc.acm"
  | |   |     |   |   "CFBundleIdentifierKernel" = "com.apple.driver.usb.cdc.acm"
  | |   |     |         "IOTTYDevice" = "usbmodem574C0347731"
  | |   |     |         "IOCalloutDevice" = "/dev/cu.usbmodem574C0347731"
  | |   |     |         "IODialinDevice" = "/dev/tty.usbmodem574C0347731"
  | |   |     +-o Google Chrome
  | |   |           "IOUserClientCreator" = "pid 479, Google Chrome"
  | |   |           "IOUserClientDefaultLocking" = Yes
在终端使用这个命令, 把上面的这个信息我看看
ioreg -lirc IOUSBHostDevice
| | +-o USB Single Serial@14920000
  | |   |   "kUSBSerialNumberString" = "5691021313"
  | |   |   "Built-In" = No
  | |   |   "IOServiceDEXTEntitlements" = (("com.apple.developer.driverkit.tran$
  | |   |   "USB Serial Number" = "5691021313"
  | |   |   "IOServiceLegacyMatchingRegistryID" = 4294974205
  | |   |   "IOPowerManagement" = {"PowerOverrideOn"=Yes,"CapabilityFlags"=3276$
  | |   |   "UsbDeviceSignature" = <861ad35545043536393130323133313302000002020$
  | |   |   "sessionID" = 3510487416808
  | |   |   "USB Address" = 11
  | |   |   "non-removable" = "no"
  | |   |   "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBH$
  | |   |   "IOClassNameOverride" = "IOUSBDevice"
  | |   |   "locationID" = 345112576
  | |   |   "kUSBAddress" = 11
  | |   +-o AppleUSBHostLegacyClient
  | |   |     "IOPowerManagement" = {"DevicePowerState"=0,"CurrentPowerState"=1$
  | |   +-o AppleUSBCDCCompositeDevice
  | |   |     "IOClass" = "AppleUSBCDCCompositeDevice"
  | |   |     "CFBundleIdentifier" = "com.apple.driver.usb.cdc"
  | |   |     "IOProbeScore" = 58000
  | |   |     "bDeviceSubClass" = "*"
  | |   |     "bDeviceProtocol" = "*"
  | |   |     "CFBundleIdentifierKernel" = "com.apple.driver.usb.cdc"
  | |   | |   "IOServiceLegacyMatchingRegistryID" = 4294974212
  | |   | |   "locationID" = 345112576
  | |   | |   "IOCFPlugInTypes" = {"2d9786c6-9ef3-11d4-ad51-000a27052861"="IOUS$
  | |   | |   "IOServiceDEXTEntitlements" = (("com.apple.developer.driverkit.tr$
  | |   | |   "USB Serial Number" = "5691021313"
  | |   | |   "IOClassNameOverride" = "IOUSBInterface"
  | |   | |   "IOServiceLegacyMatchingRegistryID" = 4294974213
  | |   | |   "IODEXTMatchCount" = 1
  | |   |   |   "IOTTYSuffix" = "56910213131"
  | |   |         "IOTTYDevice" = "usbmodem56910213131"
  | |   |         "IOCalloutDevice" = "/dev/cu.usbmodem56910213131"
  | |   |         "IODialinDevice" = "/dev/tty.usbmodem56910213131"
  | |   +-o dfu-discovery
  | |   |     "IOUserClientCreator" = "pid 668, dfu-discovery"
  | |         "IOUserClientCreator" = "pid 450, Google Chrome"
方便加一下你微信吗,你的电脑驱动加载的优先级好像出现了异常,我单独给你一个安装包试试
私信发你了
问题已经解决,非常感谢悠灵的技术支持!
