CH340
我想用CH340做一个简单的工具,单片机和上位机通信,单片机除了和CH340通信,还可以传递出两个低电平信号,我想用CH340得到这两个低电平信号,但不知道上位机如何检测到传递过来的信号,应该用到的是CTS#和DSR#,请指导下在上位机程序中如何检测CTS#和DSR#变为低电平!
到参看一下windows API 函数 GetCommModemStatus 的使用。
Syntax
BOOL WINAPI GetCommModemStatus(
  __in   HANDLE hFile,
  __out  LPDWORD lpModemStat);
Parameters
  • hFile
  • A handle to the communications device. The CreateFile function returns this handle.
  • lpModemStat
  • A pointer to a variable that receives the current state of the modem control-register values. This parameter can be one or more of the following values.
    ValueMeaning
    MS_CTS_ON
    0x0010
    The CTS (clear-to-send) signal is on.
    MS_DSR_ON
    0x0020
    The DSR (data-set-ready) signal is on.
    MS_RING_ON
    0x0040
    The ring indicator signal is on.
    MS_RLSD_ON
    0x0080
    The RLSD (receive-line-signal-detect) signal is on.
