573主模式无法获取只有write属性的UUID的句柄
    使用GATT_ReadUsingCharUUID()查找句柄,无法获取write属性的UUID句柄(返回0x01),获取read属性正常
可以通过下面方式 在service 发现后的,通过传入service 的起始结束handle调用下面代码去查询:
result = GATT_DiscAllChars(centralConnHandle,centralSvcStartHdl,centralSvcEndHdl,centralTaskId);
static void centralGATTDiscoveryEvent( gattMsgEvent_t *pMsg ){
    uint8_t result ;
    PRINT("centralGATTDiscoveryEvent\r\n");
    switch(ble_db_dis_state){
        case BLE_DISC_STATE_SVC:
            // Service found, store handles
            if ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP ){
                if( pMsg->msg.findByTypeValueRsp.numInfo > 0 ){
                    centralSvcStartHdl = ATT_ATTR_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo,0);
                    centralSvcEndHdl = ATT_GRP_END_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo,0);
                    // Display Profile Service handle range
                    PRINT("Found Profile Service handle : %x ~ %x \n",centralSvcStartHdl,centralSvcEndHdl);
                if( ( pMsg->hdr.status == bleProcedureComplete )||( pMsg->method == ATT_ERROR_RSP ) ){
                      if ( centralSvcStartHdl != 0 ){
                          //central_db_dis_change_state(BLE_DISC_STATE_CHAR);
                          PRINT("GATT_DiscAllChars:%02x\r\n",result);
            break;
        case BLE_DISC_STATE_CHAR:
            // Characteristic found, store handle
            if ( pMsg->method == ATT_READ_BY_TYPE_RSP ){
                if(pMsg->msg.readByTypeRsp.numPairs > 0 ){
                    //centralCharHdl = BUILD_UINT16( pMsg->msg.readByTypeRsp.pDataList[0],
                    //                               pMsg->msg.readByTypeRsp.pDataList[1] );
                    //PRINT("Found Characteristic 1 handle : %x \n",centralCharHdl);
                    // Iterate through all three pairs found.
                    for(unsigned char i = 0; i < pMsg->msg.readByTypeRsp.numPairs ; i++){
#if 0
                            //characteristic properties
                            uint8_t char_properties = pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i + 2];
#endif
                            uint16_t char_value_handle = BUILD_UINT16(pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i+3], \
                                                            pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i + 4]);
                            //characteristic uuid length
                            uint8_t char_uuid_length = pMsg->msg.readByGrpTypeRsp.len - 5;
                            //uuid
                            uint8_t *chat_uuid = &(pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i + 5]);
                            if(sizeof(write_uuid) == char_uuid_length){
                                if(tmos_memcmp(write_uuid,chat_uuid,char_uuid_length)){
                                    PRINT("write_uuid found,handle:%02x\r\n",char_value_handle);
                                }else if(tmos_memcmp(notify_uuid,chat_uuid,char_uuid_length)){
                                    PRINT("notify uuid found,handle:%02x\r\n",char_value_handle);
                if((pMsg->hdr.status == bleProcedureComplete ) || ( pMsg->method == ATT_ERROR_RSP ) ){
                    central_db_dis_change_state(BLE_DISC_STATE_CCCD);
                    PRINT("BLE_DISC_STATE_CHAR done\r\n");
            break;
      case BLE_DISC_STATE_CCCD:
        if ( pMsg->method == ATT_READ_BY_TYPE_RSP){
                centralCCCDHdl = BUILD_UINT16( pMsg->msg.readByTypeRsp.pDataList[0],
                PRINT("Found client characteristic configuration handle : %x \n",centralCCCDHdl);
                central_enbale_notify(centralConnHandle,centralCCCDHdl);
            //centralDiscState = BLE_DISC_STATE_IDLE;
            ble_db_dis_state = BLE_DISC_STATE_IDLE;
        break;
      default:
            break;
void pv_drv_ble_center_gatt_discovery_event( gattMsgEvent_t *pMsg )
    attReadByTypeReq_t req;
    struct pv_ble_center_uuid_st uuid;
//    pv_printf("-> %d, %02X, %04X/%04X\r\n", centralDiscState, pMsg->method, pMsg->msg.handleValueNoti.handle, pMsg->msg.handleValueInd.handle);
    pv_ble_center_control(PV_BLE_CENTER_PORT(1), PV_BLE_CENTER_CTRL_GET_UUID, &uuid);
    if ( pv_drv_ble_center.discovery_state == BLE_DISC_STATE_SVC )
        if ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP &&
            pv_drv_ble_center.svc_start_handle = ATT_ATTR_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo,0);
            pv_drv_ble_center.svc_end_handle = ATT_GRP_END_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo,0);
            PV_LOG_D("Found Profile Service, UUID handle range: %x ~ %x\r\n",pv_drv_ble_center.svc_start_handle, pv_drv_ble_center.svc_end_handle);
            pv_drv_ble_center.discovery_state = BLE_DISC_STATE_UUID;
        else
            PV_LOG_W("Not Found Profile Service handle: %04X\r\n", uuid.server_uuid);
    else if (pv_drv_ble_center.discovery_state == BLE_DISC_STATE_UUID)
        // If procedure complete
        if (pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP && pMsg->hdr.status == bleProcedureComplete)
            if (pv_drv_ble_center.svc_start_handle != 0)
                PV_ASSERT(uuid.uuid_cnt);
                // Discover characteristic
                pv_drv_ble_center.discovery_state = 0;
                req.startHandle = pv_drv_ble_center.svc_start_handle;
                req.endHandle = pv_drv_ble_center.svc_end_handle;
                req.type.len = ATT_BT_UUID_SIZE;
                req.type.uuid[0] = LO_UINT16(uuid.uuid[pv_drv_ble_center.discovery_state].uuid);
                req.type.uuid[1] = HI_UINT16(uuid.uuid[pv_drv_ble_center.discovery_state].uuid);
                GATT_DiscCharsByUUID( pv_drv_ble_center.connect_handle, &req, centralTaskId );
                PV_LOG_D("Set Fonud UUID (%02X%02X)\r\n", req.type.uuid[1], req.type.uuid[0]);
    else if (pv_drv_ble_center.discovery_state < uuid.uuid_cnt)
        if ( pMsg->method == ATT_READ_BY_TYPE_RSP && pMsg->msg.readByTypeRsp.numPairs > 0 )
            pv_drv_ble_center_uuid[pv_drv_ble_center.discovery_state].uuid = uuid.uuid[pv_drv_ble_center.discovery_state].uuid;
            pv_drv_ble_center_uuid[pv_drv_ble_center.discovery_state].event = PV_BIT(pv_drv_ble_center.discovery_state);
            pv_drv_ble_center_uuid[pv_drv_ble_center.discovery_state].cb = uuid.uuid[pv_drv_ble_center.discovery_state].cb;
            pv_drv_ble_center_uuid[pv_drv_ble_center.discovery_state].permission = uuid.uuid[pv_drv_ble_center.discovery_state].permission;
            pv_drv_ble_center_uuid[pv_drv_ble_center.discovery_state].handle = BUILD_UINT16( pMsg->msg.readByTypeRsp.pDataList[0], pMsg->msg.readByTypeRsp.pDataList[1] );
            // Start do read or write
            tmos_start_task( centralTaskId, pv_drv_ble_center_uuid[pv_drv_ble_center.discovery_state].event, DEFAULT_READ_OR_WRITE_DELAY);
            // Display uuid handle
            PV_LOG_D("Found uuid (%04X) handle : %04x\r\n", uuid.uuid[pv_drv_ble_center.discovery_state].uuid, pv_drv_ble_center_uuid[pv_drv_ble_center.discovery_state].handle);
//            PV_LOG_D("permission: %d, %d/%d\r\n", uuid.uuid[centralDiscState].permission, centralDiscState, uuid.uuid_cnt);
            if (++pv_drv_ble_center.discovery_state >= uuid.uuid_cnt)
                pv_drv_ble_center.lock = FALSE;
        // Found next uuid handle
        else if ((pMsg->method == ATT_READ_BY_TYPE_RSP && pMsg->hdr.status == bleProcedureComplete) ||
                  pMsg->method == ATT_ERROR_RSP)
结论:
GATT_DiscCharsByUUID(), 可以拿到UUID句柄,可参考开源项目:https://gitee.com/zhsing/pvt/tree/wch/
