CH55x special instruction 0xA5 (MOVX @DPTR1,A)
I have designed 2 short asm modules for copy data from code or xdata.
My goal is to replace the generic memcpy () and memset() library functions for most cases.
While this is working well I have some doubts if this is interrupt save. I dont plan to use that special
auto inc feature bDPTR_AUTO_INC because i think its not worth the trouble i might get.
;void fastccpy8 (unsigned char xdata *dest, //r6r7
;                unsigned char code  *src,  //r4r5
;                unsigned char  size)       //r3
sfr XBUS_AUX = 0xA2;
?PR?_fastccpy8?FASTCCOPY  SEGMENT CODE
PUBLIC	_fastccpy8
$REGUSE _fastccpy8(R7,A,DPTR)
RSEG   ?PR?_fastccpy8?FASTCCOPY
_fastccpy8:
       MOV  XBUS_AUX,#0x01; select DPTR1, no auto inc
       MOV  DPH,R6
       MOV  DPL,R7     ;destination
       DEC  XBUS_AUX   ;select DPTR0
       MOV  DPH, R4
       MOV  DPL, R5    ;source
       mov  A,R3
       MOV  R7,A
       JZ   ?C001      ;nothing todo
?C000: CLR  A
       MOVC A,@A+DPTR   ;read source
       INC  DPTR       ;no autoinc its not irq save
       DB   0A5H       ;MOVX @DPTR1,A & INC DPTR1
       DJNZ R7,?C000
?C001: RET
I have successfully testet that in interrupt functions as well as in main context, but i still have doubts if it is working correctly in
complex applications with irqs possibly set on different priorities.
There is a simlar function fastxcpy8 for copy from xdata
Any ideas are welcome.
donot doubts about auto inc,  these instructions are single cycle.
but, DPTR and DPTR1 are two reg,
ASM: in interrupt, you need save DPH/DPL if use DPTR in interrupt, just like using&saving B.
      and, if use the copy with DPTR1, u need save DPTR1 too, by save XBUS_AUX then select,
      save all regs u changed in interrupt.
keil C: it will save DPTR auto (if used), but not include DPTR1
so, 1. disable interrupt on copy entry, so not save DPTR1 & XBUS_AUX
2. or dont call the copy in interrupt
many thanks for your sugestions.
I have compiled them into my code snippet. Cant find any downside exept after the first  calling of the copy function interrupts are globally enabled. This could be solved by reserving a bit in bit space for the EA state. I need to read the Keil docs about the correct syntax for that.
PUBLIC  _fastccpy8
_fastccpy8:
       CLR  EA
       PUSH DPH        ;save old DPTR1
       PUSH DPL
       MOV  DPH,R6
       SETB EA
       MOV  DPH, R4
       MOV  DPL, R5    ;source
       mov  A,R3
       MOV  R7,A
?C000: CLR  A
       DJNZ R7,?C000
?C001: CLR  EA         ;restore the old values
       MOV  XBUS_AUX,#0x01
       POP  DPL
       POP  DPH
       DEC  XBUS_AUX
       SETB EA
       RET
so now 2 extra bytes in stack space are used (3 if i also save XBUS_AUX).
On the longterm I am planing to create device libs for the WCH chips with a bunch of functions. Similar to the WCH debug.c but sperately compiled as library.
FOR RE-ENTER SUBROUTINE (CALLED BY BOTH MAIN PROGRAM & INTERRUPT)
_fastccpy8:
       PUSH XBUS_AUX
       PUSH DPL
       MOV  DPH,R6
       MOV  DPH, R4
       MOV  DPL, R5    ;source
       mov  A,R3
       MOV  R7,A
?C000: CLR  A
        INC  DPTR
       DJNZ R7,?C000
?C001: INC XBUS_AUX
       POP  DPL
       POP  DPH
       POP  XBUS_AUX
       RET
OR:
_fastccpy8:
       CLR  EA
       MOV  DPH,R6
       MOV  DPH, R4
       MOV  DPL, R5    ;source
       mov  A,R3
       MOV  R7,A
?C000: CLR  A
         INC DPTR
       DJNZ R7,?C000
?C001:  SETB EA
       RET
does auto inc work on MOVC A,@A+DPTR too?
In the datasheet and h files auto inc is just mentioned for MOVX (CH552)
SORRY,  AUTO INC NOT SUPPORT MOVC
