采用CH573做蓝牙主的时候问题
连接断开后返回的错误码代表上面意识,从那个手册可以看到,Disconnected...Reason:8
#define  BLE_HCI_STATUS_CODE_SUCCESS   0x00
#define  BLE_HCI_STATUS_CODE_UNKNOWN_BTLE_COMMAND   0x01
#define  BLE_HCI_STATUS_CODE_UNKNOWN_CONNECTION_IDENTIFIER   0x02
#define  BLE_HCI_AUTHENTICATION_FAILURE   0x05
#define  BLE_HCI_STATUS_CODE_PIN_OR_KEY_MISSING   0x06
#define  BLE_HCI_MEMORY_CAPACITY_EXCEEDED   0x07
#define  BLE_HCI_CONNECTION_TIMEOUT   0x08
#define  BLE_HCI_STATUS_CODE_COMMAND_DISALLOWED   0x0C
#define  BLE_HCI_STATUS_CODE_INVALID_BTLE_COMMAND_PARAMETERS   0x12
#define  BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION   0x13
#define  BLE_HCI_REMOTE_DEV_TERMINATION_DUE_TO_LOW_RESOURCES   0x14
#define  BLE_HCI_REMOTE_DEV_TERMINATION_DUE_TO_POWER_OFF   0x15
#define  BLE_HCI_LOCAL_HOST_TERMINATED_CONNECTION   0x16
#define  BLE_HCI_UNSUPPORTED_REMOTE_FEATURE   0x1A
#define  BLE_HCI_STATUS_CODE_INVALID_LMP_PARAMETERS   0x1E
#define  BLE_HCI_STATUS_CODE_UNSPECIFIED_ERROR   0x1F
#define  BLE_HCI_STATUS_CODE_LMP_RESPONSE_TIMEOUT   0x22
#define  BLE_HCI_STATUS_CODE_LMP_ERROR_TRANSACTION_COLLISION   0x23
#define  BLE_HCI_STATUS_CODE_LMP_PDU_NOT_ALLOWED   0x24
#define  BLE_HCI_INSTANT_PASSED   0x28
#define  BLE_HCI_PAIRING_WITH_UNIT_KEY_UNSUPPORTED   0x29
#define  BLE_HCI_DIFFERENT_TRANSACTION_COLLISION   0x2A
#define  BLE_HCI_PARAMETER_OUT_OF_MANDATORY_RANGE   0x30
#define  BLE_HCI_CONTROLLER_BUSY   0x3A
#define  BLE_HCI_CONN_INTERVAL_UNACCEPTABLE   0x3B
#define  BLE_HCI_DIRECTED_ADVERTISER_TIMEOUT   0x3C
#define  BLE_HCI_CONN_TERMINATED_DUE_TO_MIC_FAILURE   0x3D
#define  BLE_HCI_CONN_FAILED_TO_BE_ESTABLISHED   0x3E
主机用的是CH573,使用的是Central例程,蓝牙设备是N21的NB模组,我修改例程中的MAC地址和UUID后可以跟N21模组连接上,并通过UUID=0XFFF0获取到主服务,
Waiting for advertising..
[22-04-24 16:33:25.634]MTU: f6
[22-04-24 16:33:25.711]
[22-04-24 16:33:26.397]exchange mtu:23
[22-04-24 16:33:26.397]MTU: 17
[22-04-24 16:33:26.554]Found Profile Service handle : 1d ~ 27
[22-04-24 16:33:26.704]
[22-04-24 16:33:28.532]Param Update...
再通过UUID=0XFFF2获取handle时,获取不到,如果我不获取handle,直接将handle设置为0x24,就可以和N21模组正常收发数据。这是什么原因?
以下是更改后的UUID
#define SIMPLEPROFILE_SERV_UUID     0xFFF0
// Key Pressed UUID
#define SIMPLEPROFILE_CHAR1_UUID    0xFFF1
#define SIMPLEPROFILE_CHAR2_UUID    0xFFF2
#define SIMPLEPROFILE_CHAR3_UUID    0xFFF3
#define SIMPLEPROFILE_CHAR4_UUID    0xFFF4
#define SIMPLEPROFILE_CHAR5_UUID    0xFFF5
if(pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP &&
           pMsg->msg.findByTypeValueRsp.numInfo > 0)
            centralSvcStartHdl = ATT_ATTR_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
            centralSvcEndHdl = ATT_GRP_END_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
            // Display Profile Service handle range
            PRINT("Found Profile Service handle : %x ~ %x \n", centralSvcStartHdl, centralSvcEndHdl);
        // If procedure complete
        if((pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP &&               //ATT按类型查找值响应
            pMsg->hdr.status == bleProcedureComplete) ||                //程序完成了
           (pMsg->method == ATT_ERROR_RSP))
            if(centralSvcStartHdl != 0)
                // Discover characteristic
                centralDiscState = BLE_DISC_STATE_CHAR;
                req.startHandle = centralSvcStartHdl;
                req.endHandle = centralSvcEndHdl;
                req.type.len = ATT_BT_UUID_SIZE;
                req.type.uuid[0] = LO_UINT16(SIMPLEPROFILE_CHAR2_UUID);
                req.type.uuid[1] = HI_UINT16(SIMPLEPROFILE_CHAR2_UUID);
                GATT_ReadUsingCharUUID(centralConnHandle, &req, centralTaskId);
//                centralCharHdl = 0x24;
//                centralProcedureInProgress = FALSE;
//                // Start do read or write
//                tmos_start_task(centralTaskId, START_READ_OR_WRITE_EVT, DEFAULT_READ_OR_WRITE_DELAY);
//                // Display Characteristic 1 handle
//                PRINT("Found Characteristic 1 handle : %x \n", centralCharHdl);
//                centralDiscState = BLE_DISC_STATE_IDLE;
    else if(centralDiscState == BLE_DISC_STATE_CHAR)
        // Characteristic found, store handle
        if(pMsg->method == ATT_READ_BY_TYPE_RSP &&
           pMsg->msg.readByTypeRsp.numPairs > 0)
            centralCharHdl = BUILD_UINT16(pMsg->msg.readByTypeRsp.pDataList[0],
                                          pMsg->msg.readByTypeRsp.pDataList[1]);
将GATT_ReadUsingCharUUID(centralConnHandle, &req, centralTaskId);屏蔽,直接用注释掉的代码,就可以和从设备正常通信了。
为什么没有技术人员回复啊?
CH579 CH573 CH582 Central 例子应用说明二 (读写通知的控制说明) - debugdabiaoge - 博客园 (cnblogs.com)
获取通道handle的方法可以参考这个说明
从你的打印信息看,在获取handle的过程中有mtu的交互,可以这样试试看,在交互mtu之后再去开始发现服务获取handle。
建立工程是我选的单片机是CH573F,现在我想更改为CH571单片机,怎么更改?
如果是将573芯片切换为571芯片,需要注意这里相应的功能使用即可:
使用的工程都是官方CH573EVT
