CH579动态调整TIM2 END周期PWM丢失
代码里更新END寄存值,按手册理解会自动清零COUNT,此时PWM应该根据POLAR输出对应的状态,实际测试没有输出保持了上一次的状态继续到下一个周期开始才会
测试代码如下:
  void TMR1_IRQHandler( void )
    GPIOA_SetBits(GPIO_Pin_4);
    R8_TMR1_INT_FLAG = 0xff;
    R32_TMR2_CNT_END = 640000;
    R8_TMR2_CTRL_MOD = RB_TMR_COUNT_EN | RB_TMR_OUT_EN;//start
    GPIOA_ResetBits(GPIO_Pin_4);
  void TimInit(void)
    PWR_UnitModCfg(DISABLE, UNIT_SYS_LSE);     // 注意此引脚是LSE晶振引脚,要保证关闭才能使用其他功能
    GPIOA_ResetBits(GPIO_Pin_11);            // 配置PWM口 PA11
    GPIOA_ModeCfg(GPIO_Pin_11, GPIO_ModeOut_PP_5mA);
    GPIOA_ModeCfg(GPIO_Pin_4, GPIO_ModeOut_PP_5mA);
    R8_TMR2_CTRL_MOD = RB_TMR_ALL_CLEAR;
    R8_TMR2_CTRL_MOD = 0;//RB_TMR_OUT_POLAR;
    R32_TMR2_FIFO = 32000;//1ms
    //R8_TMR2_CTRL_MOD = RB_TMR_OUT_POLAR | RB_TMR_COUNT_EN | RB_TMR_OUT_EN;//start
    R8_TMR1_CTRL_MOD = RB_TMR_ALL_CLEAR;                                     /* 清除所有计数值 */
    R32_TMR1_CNT_END = 320000*5;                                 /* 设置定时时间 */
    R8_TMR1_CTRL_MOD = 0;                                      /* 设置定时器模式 */
    //R8_TMR1_INT_FLAG = R8_TMR1_INT_FLAG;                                  /* 清除标志 */
    R8_TMR1_INTER_EN = RB_TMR_IE_CYC_END;                                   /* 定时中断 */
    R8_TMR1_CTRL_MOD = RB_TMR_COUNT_EN;
    NVIC_EnableIRQ(TMR1_IRQn);
微信已回复,请注意查收。
这个BUG解决办法如下:
R32_TMR2_CNT_END寄存器先设置为最小3;然后设置为正确的周期即可
    R32_TMR2_CNT_END = 3;//set min value to fix pwm lost bug
