有关CH32v203 I2C问题
CH32V203 I2C1 读写24C02 EEPROM
void IIC_Init(u32 bound, u16 address)
GPIO_InitTypeDef GPIO_InitStructure={0};
I2C_InitTypeDef I2C_InitTSturcture={0};
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE );
RCC_APB1PeriphClockCmd( RCC_APB1Periph_I2C1, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init( GPIOB, &GPIO_InitStructure );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
I2C_InitTSturcture.I2C_ClockSpeed = bound;
I2C_InitTSturcture.I2C_Mode = I2C_Mode_I2C;
I2C_InitTSturcture.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitTSturcture.I2C_OwnAddress1 = address;
I2C_InitTSturcture.I2C_Ack = I2C_Ack_Enable;
I2C_InitTSturcture.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_Init( I2C1, &I2C_InitTSturcture );
I2C_Cmd( I2C1, ENABLE );
I2C_AcknowledgeConfig( I2C1, ENABLE );
用这段初始化,pb6,pb7接24C02 都正常
GPIO_PinRemapConfig(GPIO_Remap_I2C1, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
用这段初始化,PB8,PB9接24C02 就不正常
卡死在下面这段
FlagStatus I2C_GetFlagStatus(I2C_TypeDef *I2Cx, uint32_t I2C_FLAG)
    FlagStatus    bitstatus = RESET;
    __IO uint32_t i2creg = 0, i2cxbase = 0;
    i2cxbase = (uint32_t)I2Cx;
    i2creg = I2C_FLAG >> 28;
    I2C_FLAG &= FLAG_Mask;
    if(i2creg != 0)
        i2cxbase += 0x14;
    else
        I2C_FLAG = (uint32_t)(I2C_FLAG >> 16);
        i2cxbase += 0x18;
    if(((*(__IO uint32_t *)i2cxbase) & I2C_FLAG) != (uint32_t)RESET)
        bitstatus = SET;
    else
        bitstatus = RESET;
    return bitstatus;
痲烦工程师们给看一下,问题在那里
你好,需要打开复用IO时钟
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE );
引脚复用相关详细内容参考https://www.cnblogs.com/wchmcu/p/17278478.html
可以了,谢谢
