CH32V307多个触摸按键和普通ADC采样
可以提供一个CH32V307RCT6 的多个触摸按键的ADC 和 别的 ADC采样一起使用采集的例程吗?我这里不知道为啥总会有点问题,
不用这个
//    while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC))
用和这个的话
 if(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) == 0)
    else
        TK2_Data = (uint16_t)TKey1->RDATAR;
总有个ADC的值是错的
 * Touch_SW.c
 *  Created on: Nov 24, 2023
 *      Author: Administrator
#include  "Touch_SW.h"
#include "UI_Display.h"
#include "OLED_Drv.h"
extern uint8_t Touch_ADC_Time_Flag;
uint8_t Touch_SW_Flag[2];
 * @fn      Touch_Key_Init
 * @brief   Initializes Touch Key collection.
 * @return  none
void Touch_Key_Init(void)
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    ADC_InitTypeDef  ADC_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    RCC_ADCCLKConfig(RCC_PCLK2_Div8);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;//通道2
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;//通道1
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_Cmd(ADC1, ENABLE);
    TKey1->CTLR1 |= (1 << 26) | (1 << 24); // Enable TouchKey and Buffer\
    TKey1->CTLR1 |= 1 << 25;//电流减半
 * @fn      Touch_Key_Adc
 * @brief   Returns ADCx conversion result data.
 * @param   ch - ADC channel.
 *            ADC_Channel_0 - ADC Channel0 selected.
 *            ADC_Channel_1 - ADC Channel1 selected.
 *            ADC_Channel_2 - ADC Channel2 selected.
 *            ADC_Channel_3 - ADC Channel3 selected.
 *            ADC_Channel_4 - ADC Channel4 selected.
 *            ADC_Channel_5 - ADC Channel5 selected.
 *            ADC_Channel_6 - ADC Channel6 selected.
 *            ADC_Channel_7 - ADC Channel7 selected.
 *            ADC_Channel_8 - ADC Channel8 selected.
 *            ADC_Channel_9 - ADC Channel9 selected.
 *            ADC_Channel_10 - ADC Channel10 selected.
 *            ADC_Channel_11 - ADC Channel11 selected.
 *            ADC_Channel_12 - ADC Channel12 selected.
 *            ADC_Channel_13 - ADC Channel13 selected.
 *            ADC_Channel_14 - ADC Channel14 selected.
 *            ADC_Channel_15 - ADC Channel15 selected.
 *            ADC_Channel_16 - ADC Channel16 selected.
 *            ADC_Channel_17 - ADC Channel17 selected.
 * @return  val - The Data conversion value.
u16 Touch_Key1_Adc(u8 KEY1ch)
    static   uint16_t TK_Data = 0;
    ADC_RegularChannelConfig(ADC1, KEY1ch, 1, ADC_SampleTime_7Cycles5);
    TKey1->IDATAR1 = 0x08; //Charging Time
    TKey1->RDATAR = 0x8;   //Discharging Time
   else
       TK_Data =  (uint16_t)TKey1->RDATAR;
    return TK_Data;
u16 Touch_Key2_Adc(u8 KEY2ch)
    static    uint16_t TK2_Data = 0;
    ADC_RegularChannelConfig(ADC1, KEY2ch, 1, ADC_SampleTime_7Cycles5);
    else
    return TK2_Data;
//void Touch_Key_dataProcess(void)
//    static uint16_t ADCData[2] = {0};
//    ADCData[0] = Touch_Key1_Adc(ADC_Channel_1);
//    ADCData[1] = Touch_Key2_Adc(ADC_Channel_2);
void Touch_Key_Task(void)
//    static uint16_t Last_Sta[2] = {0};
//     ADCData[1]=10000;
    if(Touch_ADC_Time_Flag != 0)
        Touch_ADC_Time_Flag = 0;
        TFTLCD_Show5x7num(5,22,ADCData[0],GREED_COLOR,BACK_MAIN_COLOR);
        TFTLCD_Show5x7num(40,80,ADCData[1],GREED_COLOR,BACK_MAIN_COLOR);
别的地方还用着一个通道10在采集着别的东西
image.png不支持ADC模块与触摸按键同时采样,触摸按键结束后,可以关闭TKENABLE 进行ADC采样。
不是同一个通道的也不可以同时采样吗?
不管是ADC通道还是触摸按键都不能一起采样,ADC模块只有一个,只是无法像ADC规则组通道配置最大16组可以扫描一个一个采样。触摸按键的寄存器都是映射了ADC模块的寄存器,而且只能配置为单通道单次采样,需要来回切ADC的初始化。
好的 ,这个我明白了。能再请教一下吗?就是比如说我两个触摸按键,两个不同的通道,比如说ch1 和 ch2 ,我也是得先获取了ch1 的触摸值 再 获取ch2的触摸值这样吗?还有就是我看到手册有touch——Key1 和 touch——Key2 这个是会有指定那个ADC的那些通道之类的吗? 没有看到这块的信息。
Touch-Key2,对应ADC2,对应配置就行。
好的 感谢 大佬的耐心解答
