单SPI轮询读取W25Qxx可以使用,但SPI+DMA中断读取不知道为什么不行,麻烦帮忙看下
如题,一开始一直进不去中断,考虑可能是配置问题,但是反复对照过类似代码,应该没有缺什么了。
刚刚把DMA_ClearFlag清除标志位的2句注释了,还进了中断,不过只有上电首次            ->中断配置应该是通的。
但整个代码呈现的效果就感觉DMA没有运行,不产生中断。麻烦帮忙看下是为什么
芯片是:CH32V208RBT6
关键代码如下:
#define DataBuf_Len 128
uint8_t RxData1[DataBuf_Len],RxData2[DataBuf_Len];
//SPI2初始化
void SPI_2_DMA_Initial(void)
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
    GPIO_InitStructure.GPIO_Pin = SPI2_CSN;        //此处引脚、端口都是正确的,因为轮询读取都是可以的
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(SPI2_SS_PORT, &GPIO_InitStructure);
    GPIO_SetBits(SPI2_SS_PORT, SPI2_CSN);
    GPIO_InitStructure.GPIO_Pin = SPI2_SCK;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(SPI2_DT_PORT, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = SPI2_MISO;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin = SPI2_MOSI;
    DMA_InitTypeDef DMA_InitStructure = {0};
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Channel4);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(SPI2->DATAR));
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)RxData1;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = 1;        //后续使用时,会在函数内更改,此处就随便写了个
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel4, &DMA_InitStructure);
    DMA_Cmd(DMA1_Channel4, DISABLE);
    DMA_ClearFlag(DMA1_FLAG_GL4|DMA1_FLAG_TC4|DMA1_FLAG_HT4|DMA1_FLAG_TE4);
    DMA_ITConfig(DMA1_Channel4,DMA_IT_TC,ENABLE);
    SPI_InitTypeDef  SPI_InitStructure = {0};
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial = 0;        //??
    SPI_Init(SPI2, &SPI_InitStructure);
    SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);
    SPI_Cmd(SPI2, ENABLE);
//    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);    //在其它地方有了,就注释了
    NVIC_InitTypeDef NVIC_InitStructure = {0};
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    NVIC_EnableIRQ(DMA1_Channel4_IRQn);
//收发单字节数据
uint8_t SPI_ReadWrite_1_Byte(uint8_t byte)
    u8 i = 0;
     SPI_I2S_SendData(SPI2, byte);
     i = 0;
     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
         i++;
         if(i > 200)
             return 0;
     return SPI_I2S_ReceiveData(SPI2);
//用于读取W25Q64中地址为ReadAddr的bufsize长度数据,存储在temp_buf中
void SPI_FLASH_Get256(uint32_t ReadAddr, uint8_t *temp_buf, uint16_t bufsize)
    SPI_CS_SET_LOW();// 选择 FLASH: CS 低电平
    SPI_ReadWrite_1_Byte(CMD_READ_BUFF);
    SPI_ReadWrite_1_Byte((ReadAddr >> 16) &0xFF);
    SPI_ReadWrite_1_Byte((ReadAddr >> 8) &0xFF);
    SPI_ReadWrite_1_Byte(ReadAddr&0xFF);
    DMA_Cmd(DMA1_Channel4,DISABLE);
    DMA_ClearFlag(DMA1_FLAG_GL3|DMA1_FLAG_TC3|DMA1_FLAG_HT3|DMA1_FLAG_TE2);
    DMA1_Channel4->CNTR = bufsize;
    DMA1_Channel4->PADDR = (uint32_t)(&(SPI2->DATAR));
    DMA1_Channel4->MADDR = (uint32_t)temp_buf;
    DMA_Cmd(DMA1_Channel4,ENABLE);
void DMA1_Channel4_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast")));
    if(DMA_GetITStatus(DMA1_IT_TC4) !=RESET)
        SPI_DMA_Read_Flag = 0x00;
        SPI_CS_SET_HIGH();
        DMA_ClearITPendingBit(DMA1_IT_GL4|DMA1_IT_TC4|DMA1_IT_HT4|DMA1_IT_TE4);
补充:主频使用120MHz,也考虑过可能是SPI的速率过快,SPI_BaudRatePrescaler_4 将它分频更多8、32、64、125、256也都试过了
您好,中断中关闭DMA之后还有调用么,若方便,可将代码发过来(lzs@wch.cn)具体看一下,后续若有问题,也可以通过邮箱沟通
有的,每次使用SPI_FLASH_Get256 这个函数的时候都会进行一次调用。代码,我稍后整理一下,发你邮箱。
