CH32V003定时中断问题
使用CH32V00x评估板,芯片是CH32V003F4P6。
在中定时中断函数里面设置一个变量为1,主函数while循环里判断这个变量,执行异常。
代码见下:
/********************************** (C) COPYRIGHT *******************************
 * File Name          : main.c
 * Author             : WCH
 * Version            : V1.0.0
 * Date               : 2024/08/23
 * Description        : CH32V003 Device Peripheral Access Layer System Header File.
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* Attention: This software (modified or not) and binary are used for
* microcontroller manufactured by Nanjing Qinheng Microelectronics.
 *@Note
 *TIMER_INT
 *MODE 1 Timer count triggers update interrupt. Updata_time = psc*arr*RepetitionCounter/system
 *MODE 2 generates an update event and triggers an update interrupt.
#include"debug.h"
int runFlag = 0;
/* Mode Definition */
#defineMODE1   0
#defineMODE2   1
/* Mode Selection */
#defineMODE MODE1
//#define MODE MODE2
 * @fn      TIM1_UP_IRQHandler
 * @brief   This function handles TIM1 UP exception.
 * @return  none
void TIM1_UP_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast")));
    if(TIM_GetITStatus(TIM1, TIM_IT_Update)==SET)
        printf("--------updata\r\n");
        runFlag = 1;
    TIM_ClearITPendingBit( TIM1, TIM_IT_Update );
 * @fn      TIM1_INT_Init
 * @brief   Initializes TIM1 output compare.
 * @param   arr - the period value.
 *          psc - the prescaler value.
 * @return  none
void TIM1_INT_Init( u16 arr, u16 psc)
    NVIC_InitTypeDef NVIC_InitStructure={0};
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure={0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE );
    TIM_TimeBaseInitStructure.TIM_Period = arr;
    TIM_TimeBaseInitStructure.TIM_Prescaler = psc;
    TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInitStructure.TIM_RepetitionCounter = 50;
    TIM_TimeBaseInit( TIM1, &TIM_TimeBaseInitStructure);
    NVIC_InitStructure.NVIC_IRQChannel =TIM1_UP_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority =1;
    NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE);
 * @fn      main
 * @brief   Main program.
 * @return  none
int main(void)
    SystemCoreClockUpdate();
    Delay_Init();
#if (SDI_PRINT==SDI_PR_OPEN)
    SDI_Printf_Enable();
#else
    USART_Printf_Init(115200);
#endif
    printf("SystemClk:%d\r\n",SystemCoreClock);
    printf( "ChipID:%08x\r\n", DBGMCU_GetCHIPID() );
    TIM1_INT_Init( 100-1, 4800-1);
#if(MODE==MODE1)
    TIM_Cmd( TIM1, ENABLE );//0.5S
#elif(MODE==MODE2)
    TIM_GenerateEvent(TIM1, TIM_IT_Update);
#endif
    while(1)
        //printf("\nrunFlag is %d\n",runFlag);
        if( runFlag == 1 ){
            runFlag = 0;
            printf("--------run\r\n");
这样写的话,不会执行 printf("--------run\r\n");
但是只要改成这样:
    while(1)
        ifrunFlag == 1 ){
            runFlag = 0;
可以运行printf("--------run\r\n");
请问是什么原因
您好,可在定义的全局变量前面加个volatile试一下,防止被优化。
感谢答复,我试试 @TECH62
