串口1 DMA发送 9位格式 串口无输出,不知道什么原因
看了好多遍,感觉没啥问题啊
void USART1_CFG(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef  NVIC_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
  /* USART2 TX-->A.2   RX-->A.3 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    USART_InitStructure.USART_BaudRate = 250000;
    USART_InitStructure.USART_WordLength = USART_WordLength_9b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Tx ;    //DMX512这里只发送数据
  USART_Init(USART1, &USART_InitStructure);
//    USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
//  DMA_Cmd(DMA1_Channel4, ENABLE);                                    /* USART1 Tx */
//  DMA_Cmd(DMA1_Channel5, ENABLE);                                    /* USART1 Rx */
  USART_Cmd(USART2, ENABLE);
* Function Name  : DMA_INIT
* Description    : Configures the DMA for USART1.
* Input          : None
* Return         : None
void DMA_INIT(void)
    DMA_InitTypeDef DMA_InitStructure;
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  DMA_DeInit(DMA1_Channel4);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&USART1->DATAR);  /* USART2->DATAR:0x40004404 */
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)Tx_Buffer;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_BufferSize = DMX_CHN;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel4, &DMA_InitStructure);
//    DMA_DeInit(DMA1_Channel5);
//  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&USART2->DATAR);
//  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)RxBuffer1;
//  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
//  DMA_InitStructure.DMA_BufferSize = TxSize2;
//  DMA_Init(DMA1_Channel5, &DMA_InitStructure);
void DMX_Init()        //初始化 主函数调用
    USART1_CFG();
    DMA_INIT();
    USART_DMACmd(USART1,USART_DMAReq_Tx,ENABLE);//|USART_DMAReq_Rx
static void USART_Send9Data(void)
    uint16_t tmp;
    DMA_Cmd(DMA1_Channel4, DISABLE);                                    /* USART1 Tx */
    for(tmp=0;tmp
       Tx_Buffer[tmp] = (uint16_t)DMX_SendData[tmp]+0x0100;        //数据第9位为高
您好,大概看了一下你的程序,在串口初始化配置的时候就有有一个问题,你串口配置的是串口1,但在使能的时候配置的是串口2,如下图,建议你再仔细检查一下程序。
大意了,非常感谢;我现在只能发送一次数据,debug发现,在dma第二次数据传输后,发送完成标志位一直没有置位,所以在这里造成了死循环
请问 可能是什么原因造成的,谢谢
您好,我看你DMA的传输方式配置为正常模式,传输结束后要开启新的DMA操作,你可按照下列方法尝试一下:在关闭DMA并清除传输完成标志之后,重新配置一下DMA传输数目的大小,然后再开启DMA。可通过调用DMA_SetCurrDataCounter函数设置DMA输出数目的大小。
