用openocd如何解除读保护?
linkE+CH32V003开发板
擦除操作提示读保护,用openocd如何解除读保护啊?
...bin % ./openocd -f wch-riscv.cfg -c init -c halt -c "flash erase_sector wch_riscv 0 last" -c exit
Open On-Chip Debugger 0.11.0+dev-02215-gcc0ecfb6d-dirty (2022-11-05-14:36)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
Ready for Remote Connections
Info : WCH-LinkE-CH32V307  mod:RV version 2.7
Info : wlink_init ok
Info : This adapter doesn't support configurable speed
Info : JTAG tap: riscv.cpu tap/device found: 0x00000001 (mfg: 0x000 (), part: 0x0000, ver: 0x0)
Warn : Bypassing JTAG setup events due to errors
Info : [riscv.cpu.0] datacount=2 progbufsize=8
Info : Examined RISC-V core; found 1 harts
Info :  hart 0: XLEN=32, misa=0x40800014
[riscv.cpu.0] Target successfully examined.
Info : starting gdb server for riscv.cpu.0 on 3333
Info : Listening on port 3333 for gdb connections
Info : device id = 0x1b8cabcd
Info : flash size = 16kbytes
Error: Read-Protect Status Currently Enabled
Error: failed erasing sectors 0 to 15
/openocd -f wch-riscv.cfg -c init -c halt -c "flash protect wch_riscv 0 last  on " -c exit  开启读保护
/openocd -f wch-riscv.cfg -c init -c halt -c "flash protect wch_riscv 0 last  off " -c exit  关闭读保护
我的也是同样的错误
Open On-Chip Debugger 0.11.0+dev-02415-gfad123a16-dirty (2023-09-22-10:36)
Info : only one transport option; autoselect 'sdi'
Warn : Transport "sdi" was already selected
Started by GNU MCU Eclipse
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : WCH-LinkE  mode:RV version 2.11
Info : clock speed 6000 kHz
Info : [wch_riscv.cpu.0] datacount=2 progbufsize=8
Info : [wch_riscv.cpu.0] Examined RISC-V core; found 1 harts
Info : [wch_riscv.cpu.0]  XLEN=32, misa=0x40901125
[wch_riscv.cpu.0] Target successfully examined.
Info : starting gdb server for wch_riscv.cpu.0 on 3333
Info : accepting 'gdb' connection on tcp/3333
Info : device id = 0x5659abcd
Info : flash size = 128kbytes
Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333"
Error: error writing to flash at address 0x00000000 at offset 0x00000000
Info : dropped 'gdb' connection
这个是嘛意思 无法调试
我的CPU 是CH32V305
您好,如果是命令行的操作,请执行一下2楼关闭读保护的指令,如果是在MRS内部,可按照下图来。
