求助!CH32V307 定时器触发ADC ADC无法启动
#include "debug.h"// 包含 CH32V307 的头文件,C 标准单元库和delay()函数
#define Num 4096
/* Global Variable */
volatile uint16_t ADC_ConvertedValue;
u16 TxBuf[Num];
s16 Calibrattion_Val = 0;
void TIM2_Init(u32 Per,u32 Prescaler)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef TIM_OCInitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.TIM_Period = Per;
    TIM_TimeBaseStructure.TIM_Prescaler =Prescaler;
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
    TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//TIM_OutputState_Disable;
    TIM_OCInitStructure.TIM_Pulse = 1000;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//如果是PWM1要为Low,PWM2则为High
    TIM_OC2Init(TIM2, & TIM_OCInitStructure);
    TIM_Cmd(TIM2, ENABLE);          //使能TIMx
    TIM_CtrlPWMOutputs(TIM2, ENABLE);
* 函 数 名       : DMA1_Init
* 函数功能    : DMA 初始化
* 输    入          :
* 输    出          : 无
void DMA1_Init()
    DMA_InitTypeDef DMA_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);               //使能ADC1通道时钟
        //DMA1初始化
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->RDATAR;             //ADC1地址
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADC_ConvertedValue;       //内存地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;              //方向(从外设到内存)
    DMA_InitStructure.DMA_BufferSize = 1;                       //传输内容的大小
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //外设地址固定
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;            //内存地址固定
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord ; //外设数据单位
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord ;    //内存数据单位
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular  ;       //DMA模式:循环传输
    DMA_InitStructure.DMA_Priority = DMA_Priority_High ;        //优先级:高
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;        //禁止内存到内存的传输
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);  //配置DMA1
    DMA_ITConfig(DMA1_Channel1,DMA_IT_TC, ENABLE);      //使能传输完成中断
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    DMA_Cmd(DMA1_Channel1,ENABLE);
void  DMA1_Channel1__IRQHandler(void)   __attribute__((interrupt("WCH-Interrupt-fast")));
    if(DMA_GetITStatus(DMA1_IT_TC1)!=RESET){
        //中断处理代码
        printf("The current value =%d \r\n",ADC_ConvertedValue);
        DMA_ClearITPendingBit(DMA1_IT_TC1);
* 函 数 名       : ADC_Function_Init
* 函数功能    : 初始化ADC
* 输    入          : 无
* 输    出          : 无
void ADC_Function_Init(void)
    ADC_InitTypeDef ADC_InitStructure;
    GPIO_InitTypeDef GPIO_InitStructure;
    TIM2_Init(1000, 144-1);
    DMA1_Init();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE );
    RCC_ADCCLKConfig(RCC_PCLK2_Div8);               //初始化ADC时钟,设置时钟为PCLK2的8分频
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);          //配置PA1口为AD输入口
    ADC_DeInit(ADC1);
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;  //设置AD模式为单独模式,只使用ADC1
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;       //禁用多通道模式,启用单通道模式
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;  //不启动连续转换模式
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2; //定时器2触发
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;  //数据右对齐
    ADC_InitStructure.ADC_NbrOfChannel = 1;     //要转换通道数量
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_1Cycles5 );
    ADC_DMACmd(ADC1, ENABLE); //启动DMA
    ADC_Cmd(ADC1, ENABLE);          //使能ADC
    ADC_BufferCmd(ADC1, DISABLE);   //disable buffer
    ADC_ResetCalibration(ADC1);
    while(ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_GetCalibrationStatus(ADC1));
    Calibrattion_Val = Get_CalibrationValue(ADC1);
    ADC_BufferCmd(ADC1, ENABLE);   //enable buffer
    ADC_ExternalTrigConvCmd(ADC1, ENABLE);
* Function Name  : main
* Description    : Main program.
* Input          : None
* Return         : None
int main(void)
    Delay_Init();
    USART_Printf_Init(115200);
    printf("SystemClk:%d\r\n",SystemCoreClock);
    ADC_Function_Init();
    printf("CalibrattionValue:%d\n", Calibrattion_Val);
    while(1);
您好,附件例程为CH32V203定时器触发ADC例程,可以参考一下,CH32V307和这基本是差不多的
icon_rar.gifCH32V203 定时器触发ADC.zip
