ch32f203RC spi读取id
程序刚下载时,spi读取id是正常的,重启之后spi会多读一个0xff
/********************************** (C) COPYRIGHT *******************************
* File Name          : main.c
* Author             : WCH
* Version            : V1.0.0
* Date               : 2021/08/08
* Description        : Main program body.
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* SPDX-License-Identifier: Apache-2.0
 *@Note
 SPI接口操作FLASH外设例程:
 Master:SPI1_SCK(PA5)、SPI1_MISO(PA6)、SPI1_MOSI(PA7)。
 本例程演示 SPI 操作 Winbond W25Qxx SPIFLASH。
 注:
 pins:
    CS   —— PA2
    DO   —— PA6(SPI1_MISO)
    WP   —— 3.3V
    DI   —— PA7(SPI1_MOSI)
    CLK  —— PA5(SPI1_SCK)
    HOLD —— 3.3V
#include "debug.h"
#include "string.h"
u8 SPI_FLASH_BUF[1024];
const u8 TEXT_Buf[] = {"CH32F203 SPI FLASH W25Qxx"};
#define SIZE sizeof(TEXT_Buf)
/* Winbond SPIFalsh ID */
#define W25Q80 0XEF13
#define W25Q16 0XEF14
#define W25Q32 0XEF15
#define W25Q64 0XEF16
#define W25Q1280XEF17
/* Winbond SPIFalsh Instruction List */
#define W25X_WriteEnable  0x06
#define W25X_WriteDisable  0x04
#define W25X_ReadStatusReg0x05
#define W25X_WriteStatusReg0x01
#define W25X_ReadData    0x03
#define W25X_FastReadData  0x0B
#define W25X_FastReadDual  0x3B
#define W25X_PageProgram  0x02
#define W25X_BlockErase  0xD8
#define W25X_SectorErase  0x20
#define W25X_ChipErase  0xC7
#define W25X_PowerDown  0xB9
#define W25X_ReleasePowerDown0xAB
#define W25X_DeviceID    0xAB
#define W25X_ManufactDeviceID0x90
#define W25X_JedecDeviceID0x9F
/* Global define */
/* Global Variable */
 * @fn      SPI1_ReadWriteByte
 * @brief   SPI1 read or write one byte.
 * @param   TxData - write one byte data.
 * @return  Read one byte data.
u8 SPI1_ReadWriteByte( u8 TxData )
    u8 i = 0;
    while( SPI_I2S_GetFlagStatus( SPI3, SPI_I2S_FLAG_TXE ) == RESET )
        i++;
        if( i > 200 )
            return 0;
    SPI_I2S_SendData( SPI3, TxData );
    i = 0;
    while( SPI_I2S_GetFlagStatus( SPI3, SPI_I2S_FLAG_RXNE ) == RESET )
        i++;
        if( i > 200 )
            return 0;
    return SPI_I2S_ReceiveData( SPI3 );
 * @fn      SPI_Flash_Init
 * @brief   Configuring the SPI for operation flash.
 * @return  none
void SPI_Flash_Init( void )
      GPIO_InitTypeDef GPIO_InitStructure = {0};
    SPI_InitTypeDef  SPI_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE );
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_SPI3, ENABLE );
    GPIO_PinRemapConfig(GPIO_Remap_SPI3,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init( GPIOA, &GPIO_InitStructure );
    GPIO_SetBits( GPIOA, GPIO_Pin_15 );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init( GPIOC, &GPIO_InitStructure );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init( SPI3, &SPI_InitStructure );
    SPI_Cmd( SPI3, ENABLE );
 * @fn      SPI_Flash_ReadSR
 * @brief   Read W25Qxx status register.
 *        -BIT7  6   5   4   3   2   1   0
 *       -SPR   RV  TB  BP2 BP1 BP0 WEL BUSY
 * @return  byte - status register value.
u8 SPI_Flash_ReadSR( void )
    u8 byte = 0;
    GPIO_WriteBit( GPIOA, GPIO_Pin_15, 0 );
    SPI1_ReadWriteByte( W25X_ReadStatusReg );
    byte = SPI1_ReadWriteByte( 0Xff );
    GPIO_WriteBit( GPIOA, GPIO_Pin_15, 1 );
    return byte;
 * @fn      SPI_FLASH_Write_SR
 * @brief   Write W25Qxx status register.
 * @param   sr - status register value.
 * @return  none
void SPI_FLASH_Write_SR( u8 sr )
    SPI1_ReadWriteByte( W25X_WriteStatusReg );
    SPI1_ReadWriteByte( sr );
 * @fn      SPI_Flash_Wait_Busy
 * @brief   Wait flash free.
 * @return  none
void SPI_Flash_Wait_Busy( void )
    while( ( SPI_Flash_ReadSR() & 0x01 ) == 0x01 );
 * @fn      SPI_FLASH_Write_Enable
 * @brief   Enable flash write.
 * @return  none
void SPI_FLASH_Write_Enable( void )
    SPI1_ReadWriteByte( W25X_WriteEnable );
 * @fn      SPI_FLASH_Write_Disable
 * @brief   Disable flash write.
 * @return  none
void SPI_FLASH_Write_Disable( void )
    SPI1_ReadWriteByte( W25X_WriteDisable );
 * @fn      SPI_Flash_ReadID
 * @brief   Read flash ID.
 * @return  Temp - FLASH ID.
u16 SPI_Flash_ReadID( void )
    u16 Temp = 0;
    SPI1_ReadWriteByte( W25X_ManufactDeviceID );
    SPI1_ReadWriteByte( 0x00 );
    Temp |= SPI1_ReadWriteByte( 0xFF )<<8;
  Temp |= SPI1_ReadWriteByte( 0xFF );
    return Temp;
 * @fn      SPI_Flash_Erase_Sector
 * @brief   Erase one sector(4Kbyte).
 * @param   Dst_Addr - 0 - 2047
 * @return  none
void SPI_Flash_Erase_Sector( u32 Dst_Addr )
    Dst_Addr *= 4096;
    SPI_FLASH_Write_Enable();
    SPI_Flash_Wait_Busy();
    SPI1_ReadWriteByte( W25X_SectorErase );
    SPI1_ReadWriteByte( ( u8 )( ( Dst_Addr ) >> 16 ) );
    SPI1_ReadWriteByte( ( u8 )( ( Dst_Addr ) >> 8 ) );
    SPI1_ReadWriteByte( ( u8 )Dst_Addr );
 * @brief   Read data from flash.
 * @param   pBuffer -
 *          ReadAddr -Initial address(24bit).
 *          size - Data length.
 * @return  none
void SPI_Flash_Read(  u32 ReadAddr,u8 *pBuffer, u16 size )
    u16 i;
    SPI1_ReadWriteByte( W25X_ReadData );
    SPI1_ReadWriteByte( ( u8 )( ( ReadAddr ) >> 16 ) );
    SPI1_ReadWriteByte( ( u8 )( ( ReadAddr ) >> 8 ) );
    SPI1_ReadWriteByte( ( u8 )ReadAddr );
    for( i = 0; i < size; i++ )
        pBuffer[i] = SPI1_ReadWriteByte( 0XFF );
 * @fn      SPI_Flash_Write_Page
 * @brief   Write data by one page.
 * @param   pBuffer -
 *          WriteAddr - Initial address(24bit).
 * @return  none
void SPI_Flash_Write_Page(  u32 WriteAddr,u8 *pBuffer, u16 size )
    u16 i;
    SPI1_ReadWriteByte( W25X_PageProgram );
    SPI1_ReadWriteByte( ( u8 )( ( WriteAddr ) >> 16 ) );
    SPI1_ReadWriteByte( ( u8 )( ( WriteAddr ) >> 8 ) );
    SPI1_ReadWriteByte( ( u8 )WriteAddr );
    for( i = 0; i < size; i++ ){
        SPI1_ReadWriteByte( pBuffer[i] );
 * @fn      SPI_Flash_Write_NoCheck
 * @brief   Write data to flash.(need Erase)
 *          All data in address rang is 0xFF.
 * @param   pBuffer -
 * @return  none
void SPI_Flash_Write_NoCheck(  u32 WriteAddr,u8 *pBuffer, u16 size )
    u16 pageremain;
    pageremain = 256 - WriteAddr % 256;
    if( size <= pageremain )
        pageremain = size;
    while( 1 )
        SPI_Flash_Write_Page(  WriteAddr,pBuffer, pageremain );
        if( size == pageremain )
            break;
        else
            pBuffer += pageremain;
            WriteAddr += pageremain;
            size -= pageremain;
            if( size > 256 )
                pageremain = 256;
            else
                pageremain = size;
 * @brief   Write data to flash.(no need Erase)
 * @param   pBuffer -
 * @return  none
void SPI_Flash_Write(  u32 WriteAddr,u8 *pBuffer, u16 size )
    u32 secpos;
    u16 secoff;
    u16 secremain;
    u16 i;
    secpos = WriteAddr / 4096;
    secoff = WriteAddr % 4096;
    secremain = 4096 - secoff;
    if( size <= secremain )
        secremain = size;
    while( 1 )
        SPI_Flash_Read(  secpos * 4096,SPI_FLASH_BUF, 4096 );
        for( i = 0; i < secremain; i++ )
            if( SPI_FLASH_BUF[secoff + i] != 0XFF )
                break;
        if( i < secremain )
            SPI_Flash_Erase_Sector( secpos );
                SPI_FLASH_BUF[i + secoff] = pBuffer[i];
            SPI_Flash_Write_NoCheck( secpos * 4096, SPI_FLASH_BUF, 4096 );
        else
            SPI_Flash_Write_NoCheck(  WriteAddr,pBuffer, secremain );
        if( size == secremain )
            break;
        else
            secpos++;
            secoff = 0;
            pBuffer += secremain;
            WriteAddr += secremain;
            size -= secremain;
            if( size > 4096 )
                secremain = 4096;
            else
                secremain = size;
 * @fn      SPI_Flash_Erase_Chip
 * @brief   Erase all FLASH pages.
 * @return  none
void SPI_Flash_Erase_Chip( void )
    SPI1_ReadWriteByte( W25X_ChipErase );
 * @fn      SPI_Flash_PowerDown
 * @brief   Enter power down mode.
 * @return  none
void SPI_Flash_PowerDown( void )
    SPI1_ReadWriteByte( W25X_PowerDown );
    Delay_Us( 3 );
 * @fn      SPI_Flash_WAKEUP
 * @brief   Power down wake up.
 * @return  none
void SPI_Flash_WAKEUP( void )
    SPI1_ReadWriteByte( W25X_ReleasePowerDown );
    Delay_Us( 3 );
 * @fn      main
 * @brief   Main program.
 * @return  none
 u8 buf[1024];
 u8 buf2[1024];
int main( void )
    u8 datap[SIZE];
    u16 Flash_Model;
    u32 i=0;
  u32 j=0;
    Delay_Init();
    USART_Printf_Init( 115200 );
    printf( "SystemClk:%d\r\n", SystemCoreClock );
    SPI_Flash_Init();
    Flash_Model = SPI_Flash_ReadID();
    switch( Flash_Model )
        case W25Q80:
            printf( "W25Q80 OK!\r\n" );
            break;
        case W25Q16:
            printf( "W25Q16 OK!\r\n" );
            break;
        case W25Q32:
            printf( "W25Q32 OK!\r\n" );
            break;
        case W25Q64:
            printf( "W25Q64 OK!\r\n" );
            break;
        case W25Q128:
            printf( "W25Q128 OK!\r\n" );
            break;
        default:
            printf( "Fail!\r\n" );
            break;
//   for(j = 0; j < sizeof(buf); j++)
//        buf[j] = j%100;
////    SPI_Flash_Erase_Sector(0);
////SPI_Flash_Erase_Chip();
////    FLASH_SPI_Read(0,buf1,sizeof(buf1));
////    for(i = 0; i < sizeof(buf1); i++) {
////        printf("%d ",buf1[i]);
//    printf("\r\n");
//    SPI_Flash_Write_NoCheck(0,buf,sizeof(buf));
//    SPI_Flash_Read(0,buf2,sizeof(buf2));
//    for(i = 0; i < sizeof(buf2); i++) {
////        if (buf[i] != buf2[i]) {
////  printf("%d ",i);
////            printf("write is error\n");
// printf("%d ",buf2[i]);
    while( 1 ){
printf("Flash_Model=%x \n",Flash_Model);
Delay_Ms(200);
您好,看你程序是用SPI3读写FLASH,这边在EVT SPI_FLASH里程基础上进行修改,改为SPI3进行测试,验证测试复位没有问题,如下图,你可以对照附件例程看一下。此外,需要注意,宏定义及启动文件要改为D8,如下图。若使用我程序下载进去验证测试还有问题,可能是硬件问题,可以检查一下硬件连接是否存在问题。
icon_rar.gifCH32F203R SPI3_FLASH.zip
