能给个ch32v307两个can相互通信的例子吗
最好带原理图,谢谢
自己写人不通,不知道什么原因
/********************************** (C) COPYRIGHT *******************************
* File Name          : main.c
* Author             : WCH
* Version            : V1.0.0
* Date               : 2021/06/06
* Description        : Main program body.
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* Attention: This software (modified or not) and binary are used for
* microcontroller manufactured by Nanjing Qinheng Microelectronics.
 *@Note
 CAN test mode, including silent mode, loopback mode and loopback silent mode:
 CAN_Tx(PB9),CAN_Rx(PB8)
 Standard_Frame: includes a 32bit filter mask bit pattern.
#include "debug.h"
/* CAN Test Mode Definition */
#define SILENT_MODE             1
#define LOOPBACK_MODE           2
#define SILENT_LOOPBACK_MODE    3
/* Test Mode Selection */
#define TEST_MODE   SILENT_MODE
//#define TEST_MODE   LOOPBACK_MODE
//#define TEST_MODE   SILENT_LOOPBACK_MODE
 * @fn      CAN_Mode_Init
 * @brief   Initializes CAN communication test mode.
 *          Bps =Fpclk1/((tpb1+1+tbs2+1+1)*brp)
 * @param   tsjw - CAN synchronisation jump width.
 *          tbs2 - CAN time quantum in bit segment 1.
 *          tbs1 - CAN time quantum in bit segment 2.
 *          brp - Specifies the length of a time quantum.
 *          mode - Test mode.
 *            CAN_Mode_Normal.
 *            CAN_Mode_LoopBack.
 *            CAN_Mode_Silent.
 *            CAN_Mode_Silent_LoopBack.
 * @return  none
void CAN_Test_Mode_Init( u8 tsjw, u8 tbs2, u8 tbs1, u16 brp, u8 mode )
GPIO_InitTypeDef GPIO_InitSturcture={0};
CAN_InitTypeDef CAN_InitSturcture={0};
CAN_FilterInitTypeDef CAN_FilterInitSturcture={0};
RCC_APB2PeriphClockCmd( RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOB, ENABLE );
RCC_APB1PeriphClockCmd( RCC_APB1Periph_CAN1, ENABLE );
RCC_APB1PeriphClockCmd( RCC_APB1Periph_CAN2, ENABLE );
GPIO_PinRemapConfig( GPIO_Remap1_CAN1, ENABLE);
GPIO_InitSturcture.GPIO_Pin = GPIO_Pin_9;
GPIO_InitSturcture.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitSturcture.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init( GPIOB, &GPIO_InitSturcture);
GPIO_InitSturcture.GPIO_Pin = GPIO_Pin_8;
GPIO_InitSturcture.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitSturcture.GPIO_Pin = GPIO_Pin_6;
    GPIO_InitSturcture.GPIO_Pin = GPIO_Pin_5;
CAN_InitSturcture.CAN_TTCM = DISABLE;
CAN_InitSturcture.CAN_ABOM = DISABLE;
CAN_InitSturcture.CAN_AWUM = DISABLE;
CAN_InitSturcture.CAN_NART = ENABLE;
CAN_InitSturcture.CAN_RFLM = DISABLE;
CAN_InitSturcture.CAN_TXFP = DISABLE;
CAN_InitSturcture.CAN_Mode = mode;
CAN_InitSturcture.CAN_SJW = tsjw;
CAN_InitSturcture.CAN_BS1 = tbs1;
CAN_InitSturcture.CAN_BS2 = tbs2;
CAN_InitSturcture.CAN_Prescaler = brp;
CAN_Init( CAN1, &CAN_InitSturcture );
CAN_Init( CAN2, &CAN_InitSturcture );
CAN_FilterInitSturcture.CAN_FilterNumber = 0;
CAN_FilterInitSturcture.CAN_FilterMode = CAN_FilterMode_IdMask;
CAN_FilterInitSturcture.CAN_FilterScale = CAN_FilterScale_32bit;
CAN_FilterInitSturcture.CAN_FilterIdHigh = 0;
CAN_FilterInitSturcture.CAN_FilterIdLow = 0;
CAN_FilterInitSturcture.CAN_FilterMaskIdHigh =0;
CAN_FilterInitSturcture.CAN_FilterMaskIdLow = 0x0006;
CAN_FilterInitSturcture.CAN_FilterFIFOAssignment = CAN_Filter_FIFO1;
CAN_FilterInitSturcture.CAN_FilterActivation = DISABLE;//ENABLE;
CAN_FilterInit( &CAN_FilterInitSturcture );
 * @fn      CAN_Send_Msg
 * @brief   CAN Transmit function.
 * @param   msg - Transmit data buffer.
 *          len - Data length.
 * @return  0 - Send successful.
 *          1 - Send failed.
u8 CAN_Send_Msg( u8 *msg, u8 len )
u8 mbox;
u16 i = 0;
CanTxMsg CanTxStructure;
CanTxStructure.StdId = 0x317;
CanTxStructure.IDE = CAN_Id_Standard;
CanTxStructure.RTR = CAN_RTR_Data;
CanTxStructure.DLC = len;
for( i=0; i
CanTxStructure.Data[i] = msg[i];
mbox = CAN_Transmit(CAN1, &CanTxStructure);
i = 0;
while( ( CAN_TransmitStatus( CAN1, mbox ) != CAN_TxStatus_Ok ) && (i < 0xFFF) )
i++;
if( i == 0xFFF )
return 1;
else
return 0;
 * @fn      CAN_Receive_Msg
 * @brief   CAN Receive function.
 * @param   buf - Receive data buffer.
 * @return  CanRxStructure.DLC - Receive data length.
u8 CAN_Receive_Msg( u8 *buf )
u8 i;
CanRxMsg CanRxStructure;
if( CAN_MessagePending( CAN2, CAN_FIFO1 ) == 0)
return 0;
CAN_Receive( CAN2, CAN_FIFO1, &CanRxStructure );
for( i=0; i<8; i++ )
buf[i] = CanRxStructure.Data[i];
return CanRxStructure.DLC;
 * @fn      main
 * @brief   Main program.
 * @return  none
int main(void)
u8 i;
u8 cnt=0;
u8 tx, rx;
u8 txbuf[8];
u8 rxbuf[8];
SystemCoreClockUpdate();
Delay_Init();
USART_Printf_Init(115200);
printf("SystemClk:%d\r\n",SystemCoreClock);
printf( "ChipID:%08x\r\n", DBGMCU_GetCHIPID() );
/* Bps = 333Kbps */
#if (TEST_MODE == SILENT_MODE)
CAN_Test_Mode_Init( CAN_SJW_1tq, CAN_BS2_5tq, CAN_BS1_6tq, 12, CAN_Mode_Silent );
    printf("Slient Mode\r\n");
#elif (TEST_MODE == LOOPBACK_MODE)
CAN_Test_Mode_Init( CAN_SJW_1tq, CAN_BS2_5tq, CAN_BS1_6tq, 12, CAN_Mode_LoopBack );
    printf("LoopBack Mode\r\n");
#elif (TEST_MODE == SILENT_LOOPBACK_MODE)
CAN_Test_Mode_Init( CAN_SJW_1tq, CAN_BS2_5tq, CAN_BS1_6tq, 12, CAN_Mode_Silent_LoopBack );
printf("Silent_LoopBack Mode\r\n");
#endif
while(1)
for(i=0; i<8; i++)
txbuf[i] = cnt+i;
tx = CAN_Send_Msg( txbuf, 8 );
if( tx )
printf( "Send Failed\r\n" );
else
printf( "Send Success\r\n" );
printf( "Send Data:\r\n" );
for(i=0; i<8; i++)
printf( "%02x\r\n", txbuf[i] );
rx = CAN_Receive_Msg( rxbuf );
if( rx )
printf( "Receive Data:\r\n" );
for(i=0; i<8; i++)
else
printf( "No Receive Data\r\n" );
Delay_Ms(1000);
cnt++;
if( cnt == 0xFF)
cnt =0;
您好,麻烦你具体说一下是需要CH32V307单独一个测试板上CAN1和CAN2之间通信的例程还是需要两个测试板利用CAN实现通信的例程,若是第一种,目前没有该类例程,感觉这么做应该没有实际的应用意义吧,若是第二种,在CH32V307 EVT中就有CAN通信例程。可以通过邮箱(lzs@wch.cn)和我具体沟通一下说一下你的需求。
第一种的例子, 我调试有用
您好,第一种的例程目前没有,可以先留个邮箱,后面有会及时发你。
有这方面的例程吗,我也要打开两个can口,然后确保两个can口已经可以通信
您好,这边有个CH32V307双CAN工程,可以参考一下:
icon_rar.gifEVT-CAN1-CAN2中断.zip
