ch32v203 内部Flash那块可以用户用
image.png 用你家开发的一款产品 现在要配置掉电不丢失 这个内部flash那块是可以我自己用的 然后又读写的例程参考吗
ch32v203F6B6
void Flash_Test(void) {
    printf("FLASH Test\n");
    /*When the main frequency exceeds 100MHz, attention should be paid when
     *operating FLASH: dividing HCLK by two will result in the related peripheral
     *clock of HCLK being divided by two. Attention should be paid when using.
    RCC->CFGR0 |= (uint32_t) RCC_HPRE_DIV2; //将系统时钟的主频分频为2
    __disable_irq();
    USART_Printf_Init(115200);
    FLASH_Unlock();
    NbrOfPage = (PAGE_WRITE_END_ADDR - PAGE_WRITE_START_ADDR) / FLASH_PAGE_SIZE;
    FLASH_ClearFlag(FLASH_FLAG_BSY | FLASH_FLAG_EOP | FLASH_FLAG_WRPRTERR); //用于清除闪存操作标志位
    for (EraseCounter = 0;
            (EraseCounter < NbrOfPage) && (FLASHStatus == FLASH_COMPLETE);
            EraseCounter++) {
        FLASHStatus = FLASH_ErasePage(
                PAGE_WRITE_START_ADDR + (FLASH_PAGE_SIZE * EraseCounter)); //Erase 4KB
        if (FLASHStatus != FLASH_COMPLETE) {
            printf("FLASH Erase Fail\r\n");
        printf("FLASH Erase Suc\r\n");
    Address = PAGE_WRITE_START_ADDR;
    printf("Programing...\r\n");
    while((Address < PAGE_WRITE_END_ADDR) && (FLASHStatus == FLASH_COMPLETE))
        FLASHStatus = FLASH_ProgramOptionByteData(Address, Data);
        Address = Address + 1;
    printf("Program Cheking...\r\n");
    while((Address < PAGE_WRITE_END_ADDR) && (MemoryProgramStatus != FAILED))
        if((*(__IO uint8_t*) Address) != Data)
            MemoryProgramStatus = FAILED;
        Address += 2;
    if (MemoryProgramStatus == FAILED) {
        printf("Memory Program FAIL!\r\n");
    } else {
        printf("Memory Program PASS!\r\n");
    FLASH_Lock();
    RCC->CFGR0 &= ~(uint32_t) RCC_HPRE_DIV2;
    __enable_irq();
    printf("%08x \r\n", *(u32*) (FAST_FLASH_PROGRAM_START_ADDR));
例程是半字的写 我改成一字节写入 修改了写的数据类型为uint8  写入函数   还要改别的吗这是修改完的 但是提示写入失败  帮忙看一下谢谢啦
FLASH_Status FLASH_ProgramWord(uint32_t Address, uint32_t Data);你那个是编程用户字的函数,地址是固定的,请替换这个函数试一下
不能存uint8的数据吗
不支持单个字节编程,但是可以把数据强制转换再写进去,要是数组的话,把数组类型强制转换一下就行。根据使用半字或者字编程转换
明白谢谢
