【沁恒微CH32V307评估板】ADC_DMA实验
采集AD输入电压值,并点亮小灯。但小灯无法点亮。同时,单步运行,每次adc_value的值不一样。
int main(void) { u16 i=0; uint16_t adc_value; SystemCoreClockUpdate(); Delay_Init(); USART_Printf_Init(115200); printf("SystemClk:%d\r\n",SystemCoreClock);
         printf( "ChipID:%08x\r\n", DBGMCU_GetCHIPID() );        ADC_Function_Init();
        printf("CalibrattionValue:%d\n", Calibrattion_Val);   DMA_Tx_Init( DMA1_Channel1, (u32)&ADC1->RDATAR, (u32)TxBuf, 1024 ); DMA_Cmd( DMA1_Channel1, ENABLE ); ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_239Cycles5 ); ADC_SoftwareStartConvCmd(ADC1, ENABLE);        Delay_Ms(50); ADC_SoftwareStartConvCmd(ADC1, DISABLE); GPIO_Toggle_INIT();
        for(i=0; i<1024; i++) { printf( "%04d\r\n", Get_ConversionVal(TxBuf[i])); Delay_Ms(10); } while(1) {   adc_value=Get_ADC_Val(ADC_Channel_1);
      if( adc_value>0 )//断点处        {            GPIO_WriteBit(GPIOB, GPIO_Pin_1, (i == 0) ? (i = Bit_SET) : (i = Bit_RESET));           Delay_Ms(1000);        } } }
进入while循环,把DMA关掉,将adc_value变量加上volatile试一下,注意ADC的频率不要超过14M,供电电压要稳定,且不要超过3.6V。
