macOS VScode 工具链写芯片出错
固件无法写入芯片CH32v307,请教哪里问题?
正在执行任务: platformio run --target upload
Processing genericCH32V307VCT6 (platform: ch32v; board: genericCH32V307VCT6; framework: noneos-sdk)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ch32v/genericCH32V307VCT6.html
PLATFORM: WCH CH32V (1.0.0) > Generic CH32V307VCT6
HARDWARE: CH32V307VCT6 144MHz, 64KB RAM, 256KB Flash
DEBUG: Current (wch-link) On-board (wch-link) External (minichlink)
PACKAGES:
 - framework-wch-noneos-sdk @ 2.10000.0+sha.2cafe78
 - tool-minichlink @ 0.1.0+sha.af02ba5
 - tool-openocd-riscv-wch @ 2.1100.230329 (11.0)
 - tool-wchisp @ 0.22.230228
 - toolchain-riscv @ 1.80200.190731+sha.99cb62f
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 0 compatible libraries
Scanning dependencies...
No dependencies
Building in release mode
Checking size .pio/build/genericCH32V307VCT6/firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [          ]   3.4% (used 2220 bytes from 65536 bytes)
Flash: [          ]   3.0% (used 7816 bytes from 262144 bytes)
Configuring upload protocol...
AVAILABLE: isp, minichlink, wch-link
CURRENT: upload_protocol = wch-link
Uploading .pio/build/genericCH32V307VCT6/firmware.elf
Open On-Chip Debugger 0.11.0+dev-02415-gfad123a16-dirty (2023-03-02-19:26)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
debug_level: 1
Warn : Transport "sdi" was already selected
Ready for Remote Connections
Error: open failed
*** [upload] Error 1
========================== [FAILED] Took 1.10 seconds ==========================
 *  终端进程“platformio 'run', '--target', 'upload'”已终止,退出代码: 1。
 *  终端将被任务重用,按任意键关闭。
配置文件内容
platformio.ini
[env:genericCH32V307VCT6]
platform = ch32v
board = genericCH32V307VCT6
framework = noneos-sdk
虽然但是但是虽然,线没插好什么的也会这样。你可以先试试重新插拔 WCHLink,重新连接 WCHLink 和板子(
您好,可以参考一下下帖回复排查一下问题,后续若有问题,可通过邮箱(lzs@wch.cn)和我具体沟通一下
https://www.wch.cn/bbs/thread-109012-1.html
