CH32V303VCT6 memcpy问题
uint8_t handle_pb620_receive(char *buffer)
    uint8_t return_byte=0;
    memset(buffer,0,USART_BUF_pb620);
    if(fifo_pb620.buffer[fifo_pb620.buf_count]!=0)
        uint16_t i;
        fifo_pb620.clear = 0;
        i = fifo_pb620.buffer[fifo_pb620.buf_count];
        if(fifo_pb620.in < fifo_pb620.out)
            for (uint16_t var = 0; var < fifo_pb620.buffer[fifo_pb620.buf_count]; ++var)
                buffer[var] = usart_struct_bufer_pb620.RX_Buffer[fifo_pb620.in + var];
//            memcpy(&buffer[0],&(usart_struct_bufer_pb620.RX_Buffer[fifo_pb620.in]),fifo_pb620.buffer[fifo_pb620.buf_count]);
        else
            for (uint16_t var = 0; var < (USART_BUF_pb620 - fifo_pb620.in); ++var)
//            memcpy(&buffer[0],&(usart_struct_bufer_pb620.RX_Buffer[fifo_pb620.in]),USART_BUF_pb620 - fifo_pb620.in);
            for(uint16_t k=0;k
                buffer[USART_BUF_pb620 - fifo_pb620.in + k] = usart_struct_bufer_pb620.RX_Buffer[k];
下面是map文件
 .bss.usart_struct_bufer_pb620
                0x000000002000041c      0x384 ./drive/usart/drive_usart_pb620.o
                0x000000002000041c                usart_struct_bufer_pb620
 .bss.calendar  0x00000000200007a0        0xa ./drive/rtc/bsp_rtc.o
                0x00000000200007a0                calendar
 *fill*         0x00000000200007aa        0x2
 .bss.pb620_check_auto_send_cmd
                0x00000000200007ac       0x14 ./Application/app_usart/app_usart_pb620.o
                0x00000000200007ac                pb620_check_auto_send_cmd
 .bss.struct_gas_offline_data
                0x00000000200007c0       0x48 ./Application/app_usart/app_usart_pb620.o
                0x00000000200007c0                struct_gas_offline_data
#define FIFO_len_pb620              50                      //FIFO缓存区存储每次接收的数据长度
#define USART_BUF_pb620             300                      //接收数据长度
typedef struct
    uint8_t    RX_Buffer[USART_BUF_pb620];                     //接收数组
    uint8_t    TX_Buffer[USART_BUF_pb620];                     //发送数组
    uint8_t    com[USART_BUF_pb620];                           //用于处理数据
}USART_buffer_pb620;
USART_buffer_pb620   usart_struct_bufer_pb620;
handle_pb620_receive中的参数是usart_struct_bufer_pb620.com,在使用memcpy时,每次拷贝的细节为41个,程序运行一段时间后,会导致后面定义的变量struct_gas_offline_data中的数据为memcpy拷贝的最后几个字节,该段程序在keil中使用时未出现问题。后来将memcpy更改为for循环拷贝,就没有问题。怀疑指针的地址指错了。不知道是什么原因引起的。
您好,关于你这段代码,在for循环中,你是使用的++var,就导致var第一个值是从1开始的,不是从0开始的,但当你使用memcpy时,是从0开始拷贝的,拷贝的是完整的fifo_pb620.buffer[fifo_pb620.buf_count]个数据,这是一个区别,你使用memcpy时可以从1开始试一下。若方便,可将你的工程发过来我这边具体看一下,后续若有问题,可通过邮箱(lzs@wch.cn)和我沟通。
