ch32v307输入捕获的中断在每次上电是立马进入,并没有上升沿信号输入,是什么问题
想要利用ch32v307的输入捕获来获取3个通道中接收到上升沿信号时,定时器的计数值,可是每次上电后,发现立马就进入输入捕获中断,导致出错,是哪里的问题,代码是在例程的基础上进行修改的
main代码如下
/********************************** (C) COPYRIGHT *******************************
* File Name          : main.c
* Author             : WCH
* Version            : V1.0.0
* Date               : 2021/06/06
* Description        : Main program body.
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* Attention: This software (modified or not) and binary are used for
* microcontroller manufactured by Nanjing Qinheng Microelectronics.
 *@Note
Input capture routine:
 TIM1_CH1(PA8)
 This example demonstrates the TIM_CH1(PA8) pin floating input, which detects an edge
  transition to trigger a TIM1 capture interrupt,
 The rising edge triggers the TIM_IT_CC1 interrupt, and the falling edge triggers the
  TIM_IT_CC2 interrupt.
#include "debug.h"
#include "math.h"
#define x1 0
#define y1 75
#define x2 0
#define y2 0
#define x3 100
#define y3 0
u32 mic1=0;
u32 mic2=0;
u32 mic3=0;
u16 time=0;
u16 state1=0;
u16 state2=0;
u16 state3=0;
u16 i=0;
u16 x;
u16 y;
u32 t12;
u32 t13;
u32 t23;
 * @fn      Input_Capture_Init
 * @brief   Initializes TIM1 input capture.
 * @param   arr - the period value.
 *          psc - the prescaler value.
 *          ccp - the pulse value.
 * @return  none
void cal(void);
void Input_Capture_Init( u16 arr, u16 psc )
GPIO_InitTypeDef GPIO_InitStructure={0};
TIM_ICInitTypeDef TIM_ICInitStructure={0};
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure={0};
NVIC_InitTypeDef NVIC_InitStructure={0};
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_TIM1, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init( GPIOA, &GPIO_InitStructure);
GPIO_ResetBits( GPIOA, GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 );
TIM_TimeBaseInitStructure.TIM_Period = arr;
TIM_TimeBaseInitStructure.TIM_Prescaler = psc;
TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInitStructure.TIM_RepetitionCounter =  0x00;
TIM_TimeBaseInit( TIM1, &TIM_TimeBaseInitStructure);
TIM_ICInitStructure.TIM_Channel = TIM_Channel_1 | TIM_Channel_2 | TIM_Channel_3;
TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
TIM_ICInitStructure.TIM_ICFilter = 0x00;
TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
TIM_ICInit(TIM1, &TIM_ICInitStructure);
NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
TIM_ITConfig( TIM1, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3, ENABLE );
TIM_SelectInputTrigger( TIM1, TIM_TS_TI1FP1 );
//TIM_SelectSlaveMode( TIM1, TIM_SlaveMode_Reset );
//TIM_SelectMasterSlaveMode( TIM1, TIM_MasterSlaveMode_Enable );
TIM_Cmd( TIM1, ENABLE );
void TIM1_CC_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast")));
void TIM1_UP_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast")));
    TIM_SetCounter( TIM1, 0 );
    i++;
    if( (TIM_GetITStatus( TIM1, TIM_IT_CC1 ) != RESET) && (state1==0))
            state1=1;
            time++;
            mic1=(TIM_GetCounter(TIM1)+(i*65535));
            TIM_ClearITPendingBit( TIM1, TIM_IT_CC1 );
            //printf( "CH4_Val:%d\r\n", TIM_GetCapture1( TIM1 ));
            //printf("进入中断1\r");
            printf("%d\r",mic1);
            if(time==3)
                    state1=0;state2=0;state3=0;
                    cal();
                    Delay_Ms(1000);
    if( TIM_GetITStatus( TIM1, TIM_IT_CC2 ) != RESET && state2==0)
            state2=1;
            time++;
            mic2=(TIM_GetCounter(TIM1)+(i*65535));
            TIM_ClearITPendingBit( TIM1, TIM_IT_CC2 );
            //printf( "CH4_Val:%d\r\n", TIM_GetCapture2( TIM1 ));
            //printf("进入中断2\r");
            printf("%d\r",mic2);
            if(time==3)
                            cal();
                            Delay_Ms(1000);
    if( TIM_GetITStatus( TIM1, TIM_IT_CC3 ) != RESET && state3==0)
            state3=1;
            time++;
            TIM_ClearITPendingBit( TIM1, TIM_IT_CC3 );
            //printf( "CH4_Val:%d\r\n", TIM_GetCapture3( TIM1 ));
            //printf("进入中断3\r");
            //TIM_SetCounter( TIM1, 0 );
            printf("%d\r",mic3);
            if(time==3)
                            cal();
                            Delay_Ms(1000);
 * @fn      main
 * @brief   Main program.
 * @return  none
int main(void)
USART_Printf_Init(115200);
SystemCoreClockUpdate();
printf("SystemClk:%d\r\n",SystemCoreClock);
printf( "ChipID:%08x\r\n", DBGMCU_GetCHIPID() );
    Input_Capture_Init( 0xFFFF, 144-1 );
while(1);
void cal()
    t12=mic1-mic2;
    t13=mic1-mic3;
    t23=mic2-mic3;
    printf("%d\r",t12);printf("%d\n",t13);printf("%d\n",t23);
    for(;x<=100;x++)
        for(;y<=75;y++)
            if((fabs((sqrtf(x*x+(y1-y)*(y1-y))-sqrtf(x*x+y*y))-t12*0.034)<5) && (fabs((sqrtf(x*x+(y1-y)*(y1-y))-sqrtf(y*y+(x3-x)*(x3-x)))-t13*0.034)<5) && (fabs((sqrtf(x*x+y*y)-sqrtf(y*y+(x3-x)*(x3-x)))-t23*0.034)<5))
                printf("X=%d\r",x);printf("Y=%d\n",y);
您好,建议你在对输入捕获引脚进行初始化配置的时候,若是上升沿捕获,可以将引脚配置成下拉输入模式,你可以修改试一下。若后续还有问题,可通过邮箱(lzs@wch.cn)和我沟通,这边可以给你提供一个参考例程。或留个邮箱,直接发你也行。
