USBHS 中断丢失
    大家好,我在基于官网CH372Device调程序的时候发现,开启2个中断,一个是TIM8 1ms的中断,另一个是USBHS中断,发现USBHS中断标志USBHS_Endp_Busy 一直为 busy 状态,TIM8定时器的中断会干扰USBHS中断,如果只有USBHS中断的话,程序压测能正常运行,一开启TIM8 1ms中断后,程序运行1~2分钟后,相应端点的USBHS_Endp_Busy 一直为busy,就像USBHS中断丢失了一样,各位大佬有遇到过类似问题吗???。下面是部分代码:
TIM8:
void TIM8_UP_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast")));
    if(TIM_GetFlagStatus(TIM8, TIM_FLAG_Update) != RESET)
        TIM_ClearFlag(TIM8, TIM_FLAG_Update);
//        ledTimerCnt++;
//        if(ledTimerCnt > 500)
//            ledTimerCnt = 0;
//            led_tongle();
        PeriodMessagesTimer();
USBHS:
void USBHS_IRQHandler( void )
    uint8_t  intflag, intst, errflag;
    uint16_t len, i;
    intflag = USBHSD->INT_FG;
    intst = USBHSD->INT_ST;
    if( intflag & USBHS_UIF_TRANSFER )
        switch ( intst & USBHS_UIS_TOKEN_MASK )
            /* data-in stage processing */
            case USBHS_UIS_TOKEN_IN:
                switch ( intst & ( USBHS_UIS_TOKEN_MASK | USBHS_UIS_ENDP_MASK ) )
                    /* end-point 0 data in interrupt */
                    case USBHS_UIS_TOKEN_IN | DEF_UEP0:
                        if( USBHS_SetupReqLen == 0 )
                            USBHSD->UEP0_RX_CTRL = USBHS_UEP_R_TOG_DATA1 | USBHS_UEP_R_RES_ACK;
                        if ( ( USBHS_SetupReqType & USB_REQ_TYP_MASK ) == USB_REQ_TYP_VENDOR )
                            /* Non-standard request endpoint 0 Data upload */
                            len = USBHS_SetupReqLen >= DEF_USBD_UEP0_SIZE ? DEF_USBD_UEP0_SIZE : USBHS_SetupReqLen;
                            memcpy(USBHS_EP0_Buf, pUSBHS_Descr, len);
                            USBHS_SetupReqLen -= len;
                            pUSBHS_Descr += len;
                            USBHSD->UEP0_TX_LEN = len;
                            USBHSD->UEP0_TX_CTRL ^= USBHS_UEP_T_TOG_DATA1;
                        else if( (USBHS_SetupReqType & USB_REQ_TYP_MASK ) == USB_REQ_TYP_STANDARD)
                            /* Standard request endpoint 0 Data upload */
                            switch( USBHS_SetupReqCode )
                                case USB_GET_DESCRIPTOR:
                                    break;
                                case USB_SET_ADDRESS:
                                    USBHSD->DEV_AD = USBHS_DevAddr;
                                    break;
                                default:
                                    USBHSD->UEP0_TX_LEN = 0;
                                    break;
                        break;
                    /* end-point 1 data in interrupt */
                    case USBHS_UIS_TOKEN_IN | DEF_UEP1:
                        USBHSD->UEP1_TX_CTRL = (USBHSD->UEP1_TX_CTRL & ~USBHS_UEP_T_RES_MASK) | USBHS_UEP_T_RES_NAK;
                        USBHSD->UEP1_TX_CTRL ^= USBHS_UEP_T_TOG_DATA1;
                        USBHS_Endp_Busy[ DEF_UEP1 ] &= ~DEF_UEP_BUSY;
                        break;
                    /* end-point 2 data in interrupt */
                    case USBHS_UIS_TOKEN_IN | DEF_UEP2:
                        USBHSD->UEP2_TX_CTRL = (USBHSD->UEP2_TX_CTRL & ~USBHS_UEP_T_RES_MASK) | USBHS_UEP_T_RES_NAK;
                        USBHSD->UEP2_TX_CTRL ^= USBHS_UEP_T_TOG_DATA1;
                        USBHS_Endp_Busy[ DEF_UEP2 ] &= ~DEF_UEP_BUSY;
                        usb_tx_busy_flag = 0;
                        break;
                    /* end-point 3 data in interrupt */
                    case USBHS_UIS_TOKEN_IN | DEF_UEP3:
                        USBHSD->UEP3_TX_CTRL = (USBHSD->UEP3_TX_CTRL & ~USBHS_UEP_T_RES_MASK) | USBHS_UEP_T_RES_NAK;
                        USBHSD->UEP3_TX_CTRL ^= USBHS_UEP_T_TOG_DATA1;
                        USBHS_Endp_Busy[ DEF_UEP3 ] &= ~DEF_UEP_BUSY;
                        break;
                    default :
                        break;
                break;
            /* data-out stage processing */
            case USBHS_UIS_TOKEN_OUT:
                switch( intst & ( USBHS_UIS_TOKEN_MASK | USBHS_UIS_ENDP_MASK ) )
                    /* end-point 0 data out interrupt */
                    case USBHS_UIS_TOKEN_OUT | DEF_UEP0:
                         len = USBHSH->RX_LEN;
                         if ( intst & USBHS_UIS_TOG_OK )
                             /* if any processing about rx, set it here */
                             if ( ( USBHS_SetupReqType & USB_REQ_TYP_MASK ) != USB_REQ_TYP_STANDARD )
                                 /* Non-standard request end-point 0 Data download */
                             else
                                 /* Standard request end-point 0 Data download */
                                 USBHSD->UEP0_TX_CTRL = USBHS_UEP_T_TOG_DATA1 | USBHS_UEP_T_RES_ACK;
                            break;
                    /* end-point 1 data out interrupt */
                    case USBHS_UIS_TOKEN_OUT | DEF_UEP1:
                            /* Write In Buffer */
                            uint16_t len;
//                            len = USBHSD->RX_LEN;
//                            USB_ProcessRxCmdData(USBHS_EP1_Rx_Buf, len);
//                            USBHSD->UEP1_RX_CTRL ^= USBHS_UEP_R_TOG_DATA1;
                            USBHSD->UEP1_RX_CTRL = ((USBHSD->UEP1_RX_CTRL) & ~USBHS_UEP_R_RES_MASK) | USBHS_UEP_R_RES_NAK;
                            USBHS_Endp_RxDataLen[DEF_UEP1] = len;
                            USBHS_Endp_RxDataFlag[DEF_UEP1] = 1;
                        break;
                    /* end-point 2 data out interrupt */
                    case USBHS_UIS_TOKEN_OUT | DEF_UEP2:
//                            USBHSD->UEP2_RX_CTRL = ((USBHSD->UEP2_RX_CTRL) & ~USBHS_UEP_R_RES_MASK) | USBHS_UEP_R_RES_NAK;
//                            len = (uint16_t)(USBHSD->RX_LEN);
//                            USB_ProcessRxData(USBHS_EP2_Rx_Buf, len);
//                            USBHSD->UEP2_RX_CTRL ^= USBHS_UEP_R_TOG_DATA1;
//                            USBHSD->UEP2_RX_CTRL = (USBHSD->UEP2_RX_CTRL & ~USBHS_UEP_R_RES_MASK) | USBHS_UEP_R_RES_ACK;
                            USBHS_Endp_RxDataLen[DEF_UEP2] = len;
                            USBHS_Endp_RxDataFlag[DEF_UEP2] = 1;
                        break;
                    /* end-point 3 data out interrupt */
                    case USBHS_UIS_TOKEN_OUT | DEF_UEP3:
//                            USBHSD->UEP3_RX_CTRL = ((USBHSD->UEP3_RX_CTRL) & ~USBHS_UEP_R_RES_MASK) | USBHS_UEP_R_RES_NAK;
//                            USBHSD->UEP3_RX_CTRL ^= USBHS_UEP_R_TOG_DATA1;
//                            USB_ProcessRxData(USBHS_EP3_Rx_Buf, len);
//                            USBHSD->UEP3_RX_CTRL = (USBHSD->UEP3_RX_CTRL & ~USBHS_UEP_R_RES_MASK) | USBHS_UEP_R_RES_ACK;
                            USBHS_Endp_RxDataLen[DEF_UEP3] = len;
                            USBHS_Endp_RxDataFlag[DEF_UEP3] = 1;
                        break;
                    default:
                        errflag = 0xFF;
                        break;
                break;
            /* Sof pack processing */
            case USBHS_UIS_TOKEN_SOF:
                break;
            default :
                break;
        USBHSD->INT_FG = USBHS_UIF_TRANSFER;
    else if( intflag & USBHS_UIF_SETUP_ACT )
        USBHSD->UEP0_TX_CTRL = USBHS_UEP_T_TOG_DATA1 | USBHS_UEP_T_RES_NAK;
        USBHSD->UEP0_RX_CTRL = USBHS_UEP_R_TOG_DATA1 | USBHS_UEP_R_RES_NAK;
        /* Store All Setup Values */
        USBHS_SetupReqType  = pUSBHS_SetupReqPak->bRequestType;
        USBHS_SetupReqCode  = pUSBHS_SetupReqPak->bRequest;
        USBHS_SetupReqLen   = pUSBHS_SetupReqPak->wLength;
        USBHS_SetupReqValue = pUSBHS_SetupReqPak->wValue;
        USBHS_SetupReqIndex = pUSBHS_SetupReqPak->wIndex;
        len = 0;
        errflag = 0;
            if(USBHS_SetupReqIndex == 4)
                pUSBHS_Descr = Extend_Compat_ID;
                len = Extend_Compat_ID[0];
                /* Copy Descriptors to Endp0 DMA buffer */
                if( USBHS_SetupReqLen>len )
                    USBHS_SetupReqLen = len;
                len = (USBHS_SetupReqLen >= DEF_USBD_UEP0_SIZE) ? DEF_USBD_UEP0_SIZE : USBHS_SetupReqLen;
                memcpy( USBHS_EP0_Buf, pUSBHS_Descr, len );
            else if(USBHS_SetupReqIndex == 5)
                pUSBHS_Descr = Extend_Properties;
                len = Extend_Properties[0];
            else
                errflag = 0xFF;
        else if( ( USBHS_SetupReqType & USB_REQ_TYP_MASK ) == USB_REQ_TYP_STANDARD )
            /* usb standard request processing */
                /* get device/configuration/string/report/... descriptors */
                    switch( (uint8_t)(USBHS_SetupReqValue>>8) )
                        /* get usb device descriptor */
                        case USB_DESCR_TYP_DEVICE:
                            pUSBHS_Descr = MyDevDescr;
                            len = DEF_USBD_DEVICE_DESC_LEN;
                            break;
                        /* get usb configuration descriptor */
                        case USB_DESCR_TYP_CONFIG:
                            /* Query current usb speed */
                            if( ( USBHSD->SPEED_TYPE & USBHS_SPEED_TYPE_MASK ) == USBHS_SPEED_HIGH )
                                /* High speed mode */
                                USBHS_DevSpeed = USBHS_SPEED_HIGH;
                                USBHS_DevMaxPackLen = DEF_USBD_HS_PACK_SIZE;
                            else
                                /* Full speed mode */
                                USBHS_DevSpeed = USBHS_SPEED_FULL;
                                USBHS_DevMaxPackLen = DEF_USBD_FS_PACK_SIZE;
                            /* Load usb configuration descriptor by speed */
                            if( USBHS_DevSpeed == USBHS_SPEED_HIGH )
                                pUSBHS_Descr = MyCfgDescr_HS;
                                len = DEF_USBD_CONFIG_HS_DESC_LEN;
                            else
                                pUSBHS_Descr = MyCfgDescr_FS;
                                len = DEF_USBD_CONFIG_FS_DESC_LEN;
                            break;
                        /* get usb string descriptor */
                        case USB_DESCR_TYP_STRING:
                            switch( (uint8_t)(USBHS_SetupReqValue&0xFF) )
                                /* Descriptor 0, Language descriptor */
                                case DEF_STRING_DESC_LANG:
                                    pUSBHS_Descr = MyLangDescr;
                                    len = DEF_USBD_LANG_DESC_LEN;
                                    break;
                                /* Descriptor 1, Manufacturers String descriptor */
                                case DEF_STRING_DESC_MANU:
                                    pUSBHS_Descr = MyManuInfo;
                                    len = DEF_USBD_MANU_DESC_LEN;
                                    break;
                                /* Descriptor 2, Product String descriptor */
                                case DEF_STRING_DESC_PROD:
                                    pUSBHS_Descr = MyProdInfo;
                                    len = DEF_USBD_PROD_DESC_LEN;
                                    break;
                                /* Descriptor 3, Serial-number String descriptor */
                                case DEF_STRING_DESC_SERN:
                                    pUSBHS_Descr = MySerNumInfo;
                                    len = DEF_USBD_SN_DESC_LEN;
                                    break;
                                case 0xEE:
                                    pUSBHS_Descr = OS_DESC;
                                    len = OS_DESC[0];
                                    break;
                                default:
                                    errflag = 0xFF;
                                    break;
                            break;
                        /* get usb device qualify descriptor */
                        case USB_DESCR_TYP_QUALIF:
                            pUSBHS_Descr = MyQuaDesc;
                            len = DEF_USBD_QUALFY_DESC_LEN;
                            break;
                        /* get usb BOS descriptor */
                        case USB_DESCR_TYP_BOS:
                            /* USB 2.00 DO NOT support BOS descriptor */
                            errflag = 0xFF;
                            break;
                        /* get usb other-speed descriptor */
                        case USB_DESCR_TYP_SPEED:
                                memcpy( &TAB_USB_HS_OSC_DESC[ 2 ], &MyCfgDescr_FS[ 2 ], DEF_USBD_CONFIG_FS_DESC_LEN - 2 );
                                pUSBHS_Descr = ( uint8_t * )&TAB_USB_HS_OSC_DESC[ 0 ];
                            else if( USBHS_DevSpeed == USBHS_SPEED_FULL )
                                memcpy( &TAB_USB_FS_OSC_DESC[ 2 ], &MyCfgDescr_HS[ 2 ], DEF_USBD_CONFIG_HS_DESC_LEN - 2 );
                                pUSBHS_Descr = ( uint8_t * )&TAB_USB_FS_OSC_DESC[ 0 ];
                            else
                                errflag = 0xFF;
                            break;
                        default :
                            errflag = 0xFF;
                            break;
                    break;
                /* Set usb address */
                    USBHS_DevAddr = (uint16_t)(USBHS_SetupReqValue&0xFF);
                    break;
                /* Get usb configuration now set */
                case USB_GET_CONFIGURATION:
                    USBHS_EP0_Buf[0] = USBHS_DevConfig;
                    if ( USBHS_SetupReqLen > 1 )
                        USBHS_SetupReqLen = 1;
                    break;
                /* Set usb configuration to use */
                case USB_SET_CONFIGURATION:
                    USBHS_DevConfig = (uint8_t)(USBHS_SetupReqValue&0xFF);
                    USBHS_DevEnumStatus = 0x01;
                    break;
                /* Clear or disable one usb feature */
                case USB_CLEAR_FEATURE:
                    if( ( USBHS_SetupReqType & USB_REQ_RECIP_MASK ) == USB_REQ_RECIP_DEVICE )
                        /* clear one device feature */
                        if((uint8_t)(USBHS_SetupReqValue&0xFF) == 0x01)
                            /* clear usb sleep status, device not prepare to sleep */
                            USBHS_DevSleepStatus &= ~0x01;
                        else
                            errflag = 0xFF;
                    else if ( ( USBHS_SetupReqType & USB_REQ_RECIP_MASK ) == USB_REQ_RECIP_ENDP )
                        /* Set End-point Feature */
                        if( (uint8_t)(USBHS_SetupReqValue&0xFF) == USB_REQ_FEAT_ENDP_HALT )
                            /* Clear End-point Feature */
                            switch( (uint8_t)(USBHS_SetupReqIndex&0xFF) )
                                case (DEF_UEP1 | DEF_UEP_OUT):
                                    /* Set End-point 1 OUT ACK */
                                    USBHSD->UEP1_RX_CTRL = USBHS_UEP_R_RES_NAK;
                                    break;
                                case (DEF_UEP1 | DEF_UEP_IN):
                                    /* Set End-point 2 IN NAK */
                                    USBHSD->UEP1_TX_CTRL = USBHS_UEP_T_RES_NAK;
                                    break;
                                case (DEF_UEP3 | DEF_UEP_OUT):
                                    /* Set End-point 3 OUT ACK */
                                    USBHSD->UEP3_RX_CTRL = USBHS_UEP_R_RES_NAK;
                                    break;
                                case (DEF_UEP4 | DEF_UEP_IN):
                                    /* Set End-point 4 IN NAK */
                                    USBHSD->UEP4_TX_CTRL = USBHS_UEP_T_RES_NAK;
                                    break;
                                case (DEF_UEP5 | DEF_UEP_OUT):
                                    /* Set End-point 5 OUT ACK */
                                    USBHSD->UEP5_RX_CTRL = USBHS_UEP_R_RES_NAK;
                                    break;
                                case (DEF_UEP6 | DEF_UEP_IN):
                                    /* Set End-point 6 IN NAK */
                                    USBHSD->UEP6_TX_CTRL = USBHS_UEP_T_RES_NAK;
                                    break;
                                default:
                                    errflag = 0xFF;
                                    break;
                        else
                            errflag = 0xFF;
                    else
                        errflag = 0xFF;
                    break;
                /* set or enable one usb feature */
                case USB_SET_FEATURE:
                        /* Set Device Feature */
                        if( (uint8_t)(USBHS_SetupReqValue&0xFF) == USB_REQ_FEAT_REMOTE_WAKEUP )
                            if( MyCfgDescr_FS[ 7 ] & 0x20 )
                                /* Set Wake-up flag, device prepare to sleep */
                                USBHS_DevSleepStatus |= 0x01;
                            else
                                errflag = 0xFF;
                        else
                            errflag = 0xFF;
                    else if( ( USBHS_SetupReqType & USB_REQ_RECIP_MASK ) == USB_REQ_RECIP_ENDP )
                            /* Set end-points status stall */
                            switch((uint8_t)(USBHS_SetupReqIndex&0xFF) )
                                    /* Set End-point 1 OUT STALL */
                                    USBHSD->UEP1_RX_CTRL = ( USBHSD->UEP1_RX_CTRL & ~USBHS_UEP_R_RES_MASK ) | USBHS_UEP_R_RES_STALL;
                                    break;
                                    /* Set End-point 1 IN STALL */
                                    USBHSD->UEP1_TX_CTRL = ( USBHSD->UEP1_TX_CTRL & ~USBHS_UEP_T_RES_MASK ) | USBHS_UEP_T_RES_STALL;
                                    break;
                                    /* Set End-point 3 OUT STALL */
                                    USBHSD->UEP3_RX_CTRL = ( USBHSD->UEP3_RX_CTRL & ~USBHS_UEP_R_RES_MASK ) | USBHS_UEP_R_RES_STALL;
                                    break;
                                    /* Set End-point 4 IN STALL */
                                    USBHSD->UEP4_TX_CTRL = ( USBHSD->UEP4_TX_CTRL & ~USBHS_UEP_T_RES_MASK ) | USBHS_UEP_T_RES_STALL;
                                    break;
                                    /* Set End-point 5 OUT STALL */
                                    USBHSD->UEP5_RX_CTRL = ( USBHSD->UEP5_RX_CTRL & ~USBHS_UEP_R_RES_MASK ) | USBHS_UEP_R_RES_STALL;
                                    break;
                                    /* Set End-point 6 IN STALL */
                                    USBHSD->UEP6_TX_CTRL = ( USBHSD->UEP6_TX_CTRL & ~USBHS_UEP_T_RES_MASK  ) | USBHS_UEP_T_RES_STALL;
                                    break;
                                default:
                                    errflag = 0xFF;
                                    break;
                    break;
                /* This request allows the host to select another setting for the specified interface  */
                case USB_GET_INTERFACE:
                    USBHS_EP0_Buf[0] = 0x00;
                    break;
                case USB_SET_INTERFACE:
                    break;
                /* host get status of specified device/interface/end-points */
                case USB_GET_STATUS:
                    USBHS_EP0_Buf[1] = 0x00;
                        switch( (uint8_t)( USBHS_SetupReqIndex & 0xFF ) )
                             case ( DEF_UEP_OUT | DEF_UEP1 ):
                                 if( ( (USBHSD->UEP1_RX_CTRL) & USBHS_UEP_R_RES_MASK ) == USBHS_UEP_R_RES_STALL )
                                     USBHS_EP0_Buf[ 0 ] = 0x01;
                                 break;
                             case ( DEF_UEP_IN | DEF_UEP1 ):
                                 if( ( (USBHSD->UEP1_TX_CTRL) & USBHS_UEP_T_RES_MASK ) == USBHS_UEP_T_RES_STALL )
                                 break;
                             case ( DEF_UEP_OUT | DEF_UEP3 ):
                                 if( ( (USBHSD->UEP3_RX_CTRL) & USBHS_UEP_R_RES_MASK ) == USBHS_UEP_R_RES_STALL )
                                 break;
                             case ( DEF_UEP_IN | DEF_UEP4 ):
                                 if( ( (USBHSD->UEP4_TX_CTRL) & USBHS_UEP_T_RES_MASK ) == USBHS_UEP_T_RES_STALL )
                                 break;
                             case ( DEF_UEP_OUT | DEF_UEP5 ):
                                 if( ( (USBHSD->UEP5_RX_CTRL) & USBHS_UEP_R_RES_MASK ) == USBHS_UEP_R_RES_STALL )
                                 break;
                             case ( DEF_UEP_IN | DEF_UEP6 ):
                                 if( ( (USBHSD->UEP6_TX_CTRL) & USBHS_UEP_T_RES_MASK ) == USBHS_UEP_T_RES_STALL )
                                 break;
                             default:
                                 errflag = 0xFF;
                                 break;
                    else if( ( USBHS_SetupReqType & USB_REQ_RECIP_MASK ) == USB_REQ_RECIP_DEVICE )
                          if( USBHS_DevSleepStatus & 0x01 )
                              USBHS_EP0_Buf[ 0 ] = 0x02;
                    if ( USBHS_SetupReqLen > 2 )
                        USBHS_SetupReqLen = 2;
                    break;
                default:
                    errflag = 0xFF;
                    break;
        else
            /* usb non-standard request processing */
            errflag = 0xFF;
        /* errflag = 0xFF means a request not support or some errors occurred, else correct */
        if( errflag == 0xFF )
            /* if one request not support, return stall */
            USBHSD->UEP0_TX_CTRL = USBHS_UEP_T_TOG_DATA1 | USBHS_UEP_T_RES_STALL;
            USBHSD->UEP0_RX_CTRL = USBHS_UEP_R_TOG_DATA1 | USBHS_UEP_R_RES_STALL;
        else
            /* end-point 0 data Tx/Rx */
            if( USBHS_SetupReqType & DEF_UEP_IN )
                /* tx */
                len = (USBHS_SetupReqLen>DEF_USBD_UEP0_SIZE) ? DEF_USBD_UEP0_SIZE : USBHS_SetupReqLen;
            else
                /* rx */
                else
        USBHSD->INT_FG = USBHS_UIF_SETUP_ACT;
    else if( intflag & USBHS_UIF_BUS_RST )
        /* usb reset interrupt processing */
        USBHS_DevConfig = 0;
        USBHS_DevAddr = 0;
        USBHS_DevSleepStatus = 0;
        USBHS_DevEnumStatus = 0;
        USBHSD->DEV_AD = 0;
        USBHS_Device_Endp_Init( );
        USBHSD->INT_FG = USBHS_UIF_BUS_RST;
    else if( intflag & USBHS_UIF_SUSPEND )
        USBHSD->INT_FG = USBHS_UIF_SUSPEND;
        /* usb suspend interrupt processing */
        if ( USBHSD->MIS_ST & USBHS_UMS_SUSPEND  )
            USBHS_DevSleepStatus |= 0x02;
            if( USBHS_DevSleepStatus == 0x03 )
                /* Handling usb sleep here */
        else
            USBHS_DevSleepStatus &= ~0x02;
    else
        /* other interrupts */
        USBHSD->INT_FG = intflag;
部分main代码:
    if(USBHS_Endp_RxDataFlag[DEF_UEP1] > 0)
        USB_ProcessRxCmdData(USBHS_EP1_Rx_Buf, USBHS_Endp_RxDataLen[DEF_UEP1]);
        USBHS_Endp_RxDataFlag[DEF_UEP1] = 0;
        USBHSD->UEP1_RX_CTRL = (USBHSD->UEP1_RX_CTRL & ~USBHS_UEP_R_RES_MASK) | USBHS_UEP_R_RES_ACK;
        if(USBHS_Endp_RxDataFlag[DEF_UEP2] > 0)
            USB_ProcessRxData(USBHS_EP2_Rx_Buf, USBHS_Endp_RxDataLen[DEF_UEP2]);
            USBHS_Endp_RxDataFlag[DEF_UEP2] = 0;
你好,例程中USBHS_Endp_Busy这个标志位,装载完端点后数据置1,在IN完成中断里清零。
出现一直为1,一般有两种情况。
1:在装载完端点的数据后主机没有下发IN包,下发了RESET或者Clear Feature等指令,把端点重新初始化,但代码中没有对应清零busy标志位,导致一直没有数据上传,不会进入IN完成中断,busy一直为1。
2:代码中有多处操作busy标志位的地方,逻辑错乱。建议发送的时候直接调用函数USBHS_Endp_DataUp,操作尽量简洁。尤其要避免busy标志位的与或操作被中断打断的情况。
在中断里面直接收、发送大型数据包?这样的也不怕中断出不来?
