关于CH573中TIMER2的PWMDMA有些问题
void TMR2_IRQHandler(void)
    if(TMR2_GetITFlag(TMR1_2_IT_DMA_END))
        TMR2_ClearITFlag(TMR1_2_IT_DMA_END);
        PFIC_DisableIRQ(TMR2_IRQn);
我发现在DMA中断函数里加上PFIC_DisableIRQ(TMR2_IRQn);后,仿真和下载都出了些问题,把这句话注销掉就没有问题。可是注销这句话后,程序就会不停的进DMA中断,执行不了其他事件,请问该如何解决。
#include "WS2811.h"
__attribute__((aligned(4))) uint32_t PwmBuf[130];
__attribute__((aligned(4))) uint32_t GRB[3] = {18, 18, 42};
uint8_t color_count = 0;
void WS2811_Init(void)
    uint8_t i;
    GPIOA_ModeCfg(GPIO_Pin_11, GPIO_ModeOut_PP_20mA);
    TMR2_PWMCycleCfg(60);
    LED_Init();
    TMR2_DMACfg(ENABLE, (uint16_t)(uint32_t)&PwmBuf[0], (uint16_t)(uint32_t)&PwmBuf[129], Mode_Single);
    TMR2_PWMInit(High_Level, PWM_Times_1);
    PFIC_EnableIRQ(TMR2_IRQn);
    TMR2_ITCfg(ENABLE, TMR1_2_IT_DMA_END);
void WS2811_Pattern(uint32_t *GRB)
    LED_Color(GRB);
void LED_Color(uint32_t *GRB)
    uint8_t i;
    for(i = 0+color_count*24; i < 8+color_count*24; i++)
        PwmBuf[i] = GRB[0];
    for(i = 8+color_count*24; i < 16+color_count*24; i++)
        PwmBuf[i] = GRB[1];
    for(i = 16+color_count*24; i < 24+color_count*24; i++)
        PwmBuf[i] = GRB[2];
    for(i = 24+color_count*24; i < 130; i++)
        PwmBuf[i] = 0;
void LED_Init(void)
    uint8_t i, j;
    for(i = 0; i < 7; i++)
        PwmBuf[i] = 18;
    for(i = 7; i < 15; i++)
        PwmBuf[i] = 42;
    for(i = 15; i < 23; i++)
        PwmBuf[i] = 18;
    for(i = 23; i < 130; i++)
        PwmBuf[i] = 0;
    for(j = 0; j < 4; j++)
        for(i = 23+j*24; i < 31+j*24; i++)
            PwmBuf[i] = 18;
        for(i = 31+j*24; i < 39+j*24; i++)
            PwmBuf[i] = 42;
        for(i = 39+j*24; i < 47+j*24; i++)
            PwmBuf[i] = 18;
tmosTaskID WS2811_TaskID;
tmosEvents LED_ProcessEvent(tmosTaskID task_id, tmosEvents events)
    uint8_t *msgPtr;
    if(events & SYS_EVENT_MSG)
        msgPtr = tmos_msg_receive(task_id);
        if(msgPtr)
            tmos_msg_deallocate(msgPtr);
        return events ^ SYS_EVENT_MSG;
    if(events & WS2811_EVENT)
        WS2811_Pattern(GRB);
        color_count++;
        if(color_count >= 5)
            color_count = 0;
            if(GRB[0] == 42)
                GRB[0] = 18;
                GRB[1] = 42;
            else if(GRB[1] == 42)
                GRB[1] = 18;
                GRB[2] = 42;
            else if(GRB[2] == 42)
                GRB[2] = 18;
                GRB[0] = 42;
        tmos_start_task(WS2811_TaskID, WS2811_EVENT, MS1_TO_SYSTEM_TIME(500));
        return events ^ WS2811_EVENT;
    return 0;
void WS2811_Start(void)
__attribute__((interrupt("WCH-Interrupt-fast")))
__attribute__((section(".highcode")))
你好,如果是使用PWM驱动2812,是可以不使用中断的,通过DMA发送数据。比如需要20个波形,则发送21个数据,最后一个数据作为PWM的停止(全高或者全低)。
或者可以使用SPI的方式进行驱动,我们有一个SPI驱动代码可以提供参考。
@TECH_Lpc
不使用中断,是注销掉这三句吗?
????TMR2_ClearITFlag(TMR1_2_IT_DMA_END);
????PFIC_EnableIRQ(TMR2_IRQn);
????TMR2_ITCfg(ENABLE,?TMR1_2_IT_DMA_END);
可是注销掉后,这PWM不会再工作了。用逻辑分析仪的话,发现并没有波形。
至于SPI的话,因为已经用掉SPI去驱动ST7789了,所以才会使用PWM来驱动WS2811。
你好,可参考:
