为什么WCH-Link 1V3只有USB转JTAG功能用了USB2.0高速?
我兴高采烈的买了个新的WCH-LINK 1V3回来盼着用USB高速调试,结果插上电脑用USBView检查了下发现是个全速设备。细读了一下说明似乎只提到了USB转JTAG功能用的是USB2.0高速接口。
USBView读到的USB信息:
[Port10]  :  USB Composite Device
Is Port User Connectable:         yes
Is Port Debug Capable:            no
Companion Port Number:            0
Companion Hub Symbolic Link Name:
Protocols Supported:
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Device Power State:               PowerDeviceD0
       ---===>Device Information<===---
English product name: "WCH-Link"
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: Full (is not SuperSpeed or higher capable)
Device Address:                    0x05
Open Pipes:                           7
          ===>Device Descriptor<===
bLength:                           0x12
bDescriptorType:                   0x01
bcdUSB:                          0x0110
bDeviceClass:                      0xEF  -> This is a Multi-interface Function Code Device
bDeviceSubClass:                   0x02  -> This is the Common Class Sub Class
bDeviceProtocol:                   0x01  -> This is the Interface Association Descriptor protocol
bMaxPacketSize0:                   0x40 = (64) Bytes
idVendor:                        0x1A86 = Nanjing Qinherg Electronics Co., Ltd.
idProduct:                       0x8010
bcdDevice:                       0x0211
iManufacturer:                     0x01
     English (United States)  "wch.cn"
iProduct:                          0x02
     English (United States)  "WCH-Link"
iSerialNumber:                     0x03
     English (United States)  "XXXXXXXXXXXXXXX"
bNumConfigurations:                0x01
          ---===>Open Pipes<===---
          ===>Endpoint Descriptor<===
bLength:                           0x07
bDescriptorType:                   0x05
bEndpointAddress:                  0x82  -> Direction: IN - EndpointID: 2
bmAttributes:                      0x02  -> Bulk Transfer Type
wMaxPacketSize:                  0x0040 = 0x40 bytes
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x02  -> Direction: OUT - EndpointID: 2
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x81  -> Direction: IN - EndpointID: 1
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x01  -> Direction: OUT - EndpointID: 1
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x84  -> Direction: IN - EndpointID: 4
bmAttributes:                      0x03  -> Interrupt Transfer Type
bInterval:                         0x01
bLength:                           0x07
bEndpointAddress:                  0x83  -> Direction: IN - EndpointID: 3
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x03  -> Direction: OUT - EndpointID: 3
bInterval:                         0x00
       ---===>Full Configuration Descriptor<===---
          ===>Configuration Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x02
wTotalLength:                    0x0078  -> Validated
bNumInterfaces:                    0x03
bConfigurationValue:               0x01
iConfiguration:                    0x00
bmAttributes:                      0x80  -> Bus Powered
MaxPower:                          0x32 = 100 mA
          ===>IAD Descriptor<===
bLength:                           0x08
bDescriptorType:                   0x0B
bFirstInterface:                   0x00
bInterfaceCount:                   0x01
*!*ERROR:  bInterfaceCount must be greater than 1
bFunctionClass:                    0xFF  -> Interface Class Unknown to USBView
bFunctionSubClass:                 0x00
bFunctionProtocol:                 0x00
iFunction:                         0x02
          ===>Interface Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x04
bInterfaceNumber:                  0x00
bAlternateSetting:                 0x00
bNumEndpoints:                     0x04
bInterfaceClass:                   0xFF  -> Interface Class Unknown to USBView
bInterfaceSubClass:                0x80
bInterfaceProtocol:                0x55
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x08
bFirstInterface:                   0x01
bInterfaceCount:                   0x02
bFunctionClass:                    0x02  -> This is Communications (CDC Control) USB Device Interface Class
bFunctionSubClass:                 0x02
bFunctionProtocol:                 0x01
iFunction:                         0x04
bLength:                           0x09
bInterfaceNumber:                  0x01
bNumEndpoints:                     0x01
bInterfaceClass:                   0x02  -> This is Communications (CDC Control) USB Device Interface Class
bInterfaceSubClass:                0x02
bInterfaceProtocol:                0x01
iInterface:                        0x00
  -> This is a Communications (CDC Control) USB Device Interface Class
          ===>Descriptor Hex Dump<===
bLength:                           0x05
bDescriptorType:                   0x24
05 24 00 10 01
bLength:                           0x05
05 24 01 00 01
bLength:                           0x04
04 24 02 02
bLength:                           0x05
05 24 06 01 02
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bInterfaceNumber:                  0x02
bNumEndpoints:                     0x02
bInterfaceClass:                   0x0A  -> This is a CDC Data USB Device Interface Class
bInterfaceSubClass:                0x00
bInterfaceProtocol:                0x00
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
您好,WCH-LinkE除USB转JTAG接口模式,其他模式暂时不支持高速USB。
