Option Explicit
Dim iBuff As Byte
Dim buffer As arrRBuffer
Private Sub Command1_Click()            '写入D/A
Dim ss As String
ss = Hex(HScroll1.Value)
Call mStrtoVal("9040" & ss, buffer, 3)      '将输入的十六进制格式字符数据转成数值数据
bopen = CH341StreamI2C(mIndex, 3, buffer, 1, iBuff)
Label5.Caption = "输出=" & HScroll1.Value & "/输出电压=" & Format((HScroll1 / 51), "0.0")
End Sub
Private Sub Command2_Click()           'AIN0
Label1.Caption = ""
Call mStrtoVal("9040", buffer, 2)      '将输入的十六进制格式字符数据转成数值数据
bopen = CH341StreamI2C(mIndex, 2, buffer, 1, iBuff)
Label1.Caption = iBuff
End Sub
Private Sub Command3_Click()           'AIN1
Call mStrtoVal("9041", buffer, 2)      '将输入的十六进制格式字符数据转成数值数据
Label2.Caption = iBuff
End Sub
Private Sub Command4_Click()          'AIN2
Call mStrtoVal("9042", buffer, 2)      '将输入的十六进制格式字符数据转成数值数据
Label3.Caption = iBuff
End Sub
Private Sub Command5_Click()          'AIN3
Call mStrtoVal("9043", buffer, 2)      '将输入的十六进制格式字符数据转成数值数据
Label4.Caption = Format(iBuff / 51, "0.0")
End Sub
Private Sub Command6_Click()           'QUIT
CH341SetDeviceNotify 0, vbNullString, 0&
If (mOpen = True) Then CH341CloseDevice (mIndex)        '如果CH341已打开则关闭
Unload Me    '关闭窗体
End Sub
Private Sub HScroll1_Change()
End Sub
Private Sub Form_Load()
mIndex = 0
hopen = CH341OpenDevice(mIndex)
If (hopen = INVALID_HANDLE_VALUE) Then
    mOpen = False
Else
    mOpen = True
End If
Label1.Caption = ""
Label2.Caption = ""
Label3.Caption = ""
Label4.Caption = ""
Label5.Caption = ""
HScroll1.Value = 40
'设置设备插拔通知
If CH341SetDeviceNotify(mIndex, vbNullString, AddressOf mPCH341_NOTIFY_ROUTINE) = False Then
    MsgBox "设置设备插拔通知失败", vbExclamation
End If
enablebtn (mOpen)
bopen = CH341SetStream(mIndex, &H81)                    '设置同步串口流模式,高位在前,本例只能用&H80或&H81
'置D/A输出为零
Call mStrtoVal("904000", buffer, 3)                      '将输入的十六进制格式字符数据转成数值数据
bopen = CH341StreamI2C(mIndex, 3, buffer, 1, iBuff)      '置D/A输出为零
End Sub
Private Sub CH341_NOTIFY_ROUTINE_KeyUp(KeyCode As Integer, Shift As Integer)  '设备插拔通知处理程序
    mIndex = 0
    iEventStatus = KeyCode '插拔事件
    If (iEventStatus = CH341_DEVICE_ARRIVAL) Then ' 设备插入事件,CH341_DEVICE_ARRIVAL=3已经插入
        If (CH341OpenDevice(mIndex) = INVALID_HANDLE_VALUE) Then     'INVALID_HANDLE_VALUE=-1
            MsgBox "打开设备失败!", vbOK
            mOpen = False
        Else
            mOpen = True  '打开成功
        End If
    ElseIf (iEventStatus = CH341_DEVICE_REMOVE) Then ' 设备拔出事件,CH341_DEVICE_REMOVE=0已经拔出
        mOpen = False
    End If
    enablebtn (mOpen) '设备打开,按钮可用,设备没打开,按钮禁用
End Sub
Public Sub enablebtn(ByVal bEnable As Boolean)  'bEnable=true :各窗体按钮可用 ;=false:enable:各窗体按钮禁用
  With Form1
    .Command1.Enabled = bEnable
    .Command2.Enabled = bEnable
    .Command3.Enabled = bEnable
    .Command4.Enabled = bEnable
    .Command5.Enabled = bEnable
    .Frame1.Enabled = bEnable
    .Frame2.Enabled = bEnable
    .HScroll1.Enabled = bEnable
    If (bEnable = True) Then '窗体标题显示
        Form1.Caption = "USB已连接"
    Else
        Form1.Caption = "USB未连接"
    End If
  End With
End Sub
