CH376 51串口
#include "STC12C5A60AD.H"
#include
#define uchar unsigned char
#define uint unsigned int
#define S2RI =0x01;
#define S2TI =0x02;
sbit   buzzer      = P3^7;
bit RX2_busy;
bit TX2_busy;
uchar Rxbuff2;
uchar a;
void  PortInit(void)
    P1M1     = 0x07;
    P1M0     = 0x30;
    P1M0     =0x20;
    P3M1     = 0x00;
    P3M0     = 0x84;
    P4M1     = 0x00;
    P4M0     = 0x08;
void UART_init(void)
 SCON = 0x50;            //8-bit variable UART
    TMOD |= 0x20;            //Set Timer1 as 8-bit auto reload mode
    TH1 = TL1 =-3;// -(FOSC/12/32/BAUD); //Set auto-reload vaule
    TR1 = 1;                //Timer1 start run
    ES = 1;                 //Enable UART interrupt
    EA = 1;                //Open master interrupt switch
void SendData2(uchar dat)
while(TX2_busy);
TX2_busy=1;
//S2BUF = dat;
SBUF = dat;
void SendString2(char *s)
  while (*s)
        SendData2(*s++);
void  DelayUS(unsigned int  Time)
    unsigned char i;
    while(Time--)
for(i=0;i<20;i++);
void Uart_Isr() interrupt 4 using 1
if (RI)
      RI = 0;             //Clear receive interrupt flag
Rxbuff2=SBUF;
RX2_busy=0;
    if (TI)
      TI = 0;             //Clear transmit interrupt flag
      TX2_busy = 0;           //Clear transmit busy flag
voidxWriteCH376Cmd(uchar Cmd)
SendData2(0x57);
DelayUS(1000);
SendData2(0xAB);
DelayUS(1000);
SendData2(Cmd);
voidxWriteCH376Data(uchar mData)
SendData2(mData);
void  ce_shi_ming_ling(void)
xWriteCH376Cmd(0x06);
  xWriteCH376Data(0x55);
void  U_pan_mo_shi(void)
xWriteCH376Cmd(0x15); ///////????U?ì?£ê?
xWriteCH376Data(0x06);
void U_pan_lian_jie(void)
xWriteCH376Cmd(0x30);
void U_pan_chu_shi(void)
xWriteCH376Cmd(0x31);
void set_file_name(void)
         xWriteCH376Cmd(0x2F);
SendString2("CDE.TXT");
xWriteCH376Cmd(0x34);
DelayUS(1000);
Rxbuff2=0;
xWriteCH376Cmd(0x22);
void main()
UART_init();
PortInit();
buzzer=0;
while(1)
ce_shi_ming_ling();
U_pan_mo_shi();
U_pan_lian_jie();
U_pan_chu_shi();
set_file_name();
这是我的程序  测试返回值正常 但是无法在U盘中建立文件
有时候车上U盘是那个指示灯不亮  要重新掉电上电几次才可以   利用串口助手发这些指令返回值是正常的 但是无法建立文件
