01:14:13 **** Incremental Build of configuration obj for project HID_Keyboard ****
make -j8 all
c:/mounriver/mounriver_studio/toolchain/risc-v embedded gcc/bin/../lib/gcc/riscv-none-embed/8.2.0/../../../../riscv-none-embed/bin/ld.exe: cannot open linker script file : No such file or directory
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:52: HID_Keyboard.elf] Error 1
01:14:15 Build Failed. 2 errors, 0 warnings. (took 1s.602ms)
如题,代码没有变动,只是把目录改了一下,然后头文件目录重新指定过了,请问还有哪些路径需要更改
查看: 3155
回复: 1
更改了BLEDemo的路径后无法编译成功,报错为 cannot open linker script file : No such file or directory
CH397: 高集成度、低功耗USB网卡芯片
动了路径以后,对应文件的路径要改动一下。
