求助:才开始学习risc,下载提示Board chip status error 怎么处理
开始是正常的,打开了定时器中断,可以正常运行;之后再下载就提示这个错误
------------ Begin flash process of "obj\CH32V103C8T6.hex" ------------
16:16:31:527 >> Current project vendor is WCH, debugger is WCH-Link
16:16:31:528 >> Starting to Open Link in RISC-V APP mode...
16:16:31:528 >> Open Link in RISC-V APP mode Success
16:16:31:528 >> Starting to get link mode...
16:16:31:530 >> Link is under APP mode
16:16:31:530 >> Starting to compare firmware version...
16:16:31:530 >> No need to update. Already the latest version. Version is v2.3.
16:16:31:530 >> Starting to Send Chip Type...
16:16:31:570 >> Board chip status error
16:16:31:570 >> Starting to Close Link...
16:16:31:570 >> Close Link Success
---------------------------------End ----------------------------------
过了一会 板子也不运行了,重新上电也没反应了
您好,您下载的是FLASH的例程吗?FLASH的例程在操作flash没有结束时,下载会报这个错误,您可以重新上电通过串口查看一下打印,在打印128Byte Page Verity Sucess结束之后点击下载可以正常下载.您也可以把工程发我邮箱,我这边帮您看一下(fq@wch.cn).
