MRS Linux_x64_V1.60 携带的libtinfo.so.5导致公版arm-none-eabi-gdb报错
在 Ubuntu22.04下, 安装 MRS Linux_x64_V1.60 需要将 libtinfo.so.5 复制到 /usr/lib, 但是这样会导致公版的 arm-none-eabi-gdb无法使用, 具体错误为
s:~$ ldd /opt/gcc-arm/arm-gnu-toolchain-12.2.mpacbti-bet1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb
/opt/gcc-arm/arm-gnu-toolchain-12.2.mpacbti-bet1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb: /usr/lib/wch/libtinfo.so.5: version `NCURSES_TINFO_6.2.20211010' not found (required by /lib/x86_64-linux-gnu/libncursesw.so.5)
linux-vdso.so.1 (0x00007ffd53148000)
libncursesw.so.5 => /lib/x86_64-linux-gnu/libncursesw.so.5 (0x00007f3a176d9000)
libtinfo.so.5 => /usr/lib/wch/libtinfo.so.5 (0x00007f3a17400000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f3a176d4000)
libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007f3a1769a000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f3a17695000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f3a1768e000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f3a17319000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f3a170ef000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f3a1766e000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f3a16ec7000)
/lib64/ld-linux-x86-64.so.2 (0x00007f3a17720000)
s:~$ /opt/gcc-arm/arm-gnu-toolchain-12.2.mpacbti-bet1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb --version
s:~$ ldd /opt/gcc-arm/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb
/opt/gcc-arm/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb: /usr/lib/wch/libtinfo.so.5: version `NCURSES_TINFO_6.2.20211010' not found (required by /lib/x86_64-linux-gnu/libncursesw.so.5)
linux-vdso.so.1 (0x00007ffc313f2000)
libncursesw.so.5 => /lib/x86_64-linux-gnu/libncursesw.so.5 (0x00007fcfcbff1000)
libtinfo.so.5 => /usr/lib/wch/libtinfo.so.5 (0x00007fcfcbc00000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fcfcbfec000)
libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007fcfcbfb2000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fcfcbfad000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007fcfcbfa6000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fcfcbebf000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fcfcb9d6000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fcfcbe9f000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fcfcb7ae000)
/lib64/ld-linux-x86-64.so.2 (0x00007fcfcc038000)
s:~$ /opt/gcc-arm/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb --version
删除 /usr/lib/wch/libtinfo.so.5 后则工作正常
s$ /opt/gcc-arm/arm-gnu-toolchain-11.3.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb --version
GNU gdb (Arm GNU Toolchain 11.3.Rel1) 12.1.90.20220802-git
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
s$ /opt/gcc-arm/arm-gnu-toolchain-12.2.mpacbti-bet1-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb --version
GNU gdb (Arm GNU Toolchain 12.2.MPACBTI-Bet1 (Build arm-12-mpacbti.16)) 13.0.50.20220406-git
感谢您的使用与反馈,我们这边会验证并跟进该现象。
